OTG in ZCU102 with Rev 1. 0 doesn't work on the latest SDK v2017.4
Hi expert,
I noticed host mode works well, and device as well.
but when I change into "otg" mode in dts, I found USB 3.0 port(J112) can work as a device mode, which the board has no response if I insert a USB 3.0 disk into the USB 3.0 port(J112), so I think this OTG should not work, right?
Cheers,
Zumeng
jadhavs
Hi Zumeng,
ZynqUltrSclae+MPSoC  support On The Go (OTG) USB2.0 speed for host & device and not 3.0 speed.  Please have a look Xilinx's Wiki page for more help @ http://www.wiki.xilinx.com/Zynq+Ultrascale+MPSOC+Linux+USB+device+driver#OTG
jadhavs
Hi Zumeng,
Thanks a lot
