I am using a ZC702 dev board with Xilinx SDK 2016.3 under baremetal. I am attempting to pull in Lua as a static library called from my main code. I was able to get the Lua library to compile fine as a static library, but when I call the openlibs Lua gives me an out of memory panic. I have the openlibs stripped down to just the "_G" base library, but still get the error. I included the math library and had to create a gettimeofday function to get it to link.
Any advice on how to combat this memory issue? Has anyone else attempted to get Lua to run on ARM Cortex? I got this to run fine as a static library on a TI OMAP L138 ARM9.
Tim
