betontalpfa
Overrun Error on XuartLite
I have a UART link between two FPGAs, driven by XuartLite. The link is stable if the data is less than or equal 16 (the size of the HW FIFO in the IP) Greater packet causes Overrun Error.
The link should be slow enough (baud=115200) for the 100MHz Microblaze. (This means a byte arrives in each 9/115200 sec)
I read the link in polled mode, without any other tasks/IRQs, so this is a simple while loop:
while (1) {
    ReceivedCount += XUartLite_Recv(UartLitePtr,
                   RecvBuffer + ReceivedCount,
                   TEST_BUFFER_SIZE - ReceivedCount);
    if (ReceivedCount == packet_size) {
        break;
    if(
        UartLitePtr->Stats.ReceiveFramingErrors ||
        UartLitePtr->Stats.ReceiveOverrunErrors ||
        UartLitePtr->Stats.ReceiveParityErrors
        // If we got an error, print statistics.
        printStatus(UartLitePtr);
        ReceivedCountPrev = ReceivedCount;
However, I get an Overrun Error.
What's do I wrong?
betontalpfa
Sorry, it was completely my fault.
There was a printf between the send and the receive, which results in the late read of the FIFO. So when I reached this loop, the FIFO has been overrun.
betontalpfa
