Observer maciek11
PCIe project XPS 13.2 ML605
I have implemeted the exemplary project: http://www.xilinx.com/support/answers/43371.htm.
It works fine but each time I try to change something in the project I get the following errors during implementation:
Timing constraint: TS_CLK_125 = PERIOD TIMEGRP "CLK_125" TS_SYSCLK / 0.8 HIGH
50% PRIORITY 1;
 1796440 paths analyzed, 42632 endpoints analyzed, 1281 failing endpoints
 1281 timing errors detected. (1281 setup errors, 0 hold errors, 0 component switching limit errors)
 Minimum period is   9.345ns.
Slack:                  -1.345ns (requirement - (data path - clock path skew + uncertainty))
  Source:               axi_pcie_0/axi_pcie_0/comp_axi_enhanced_pcie/comp_enhanced_core_top_wrap/axi_pcie_enhanced_core_top_i/v6_pcie_v2_3_ep_inst/pcie_2_0_i/pcie_block_i (CPU)
  Destination:          axi_pcie_0/axi_pcie_0/comp_axi_pcie_mm_s/comp_slave_bridge/comp_slave_read_cpl_tlp/tag_active<7>_2_8 (FF)
  Requirement:          8.000ns
  Data Path Delay:      9.323ns (Levels of Logic = 8)
  Clock Path Skew:      0.049ns (1.683 - 1.634)
  Source Clock:         axi_aclk_out rising at 0.000ns
  Destination Clock:    axi_aclk_out rising at 8.000ns
  Clock Uncertainty:    0.071ns
  Clock Uncertainty:          0.071ns  ((TSJ^2 + DJ^2)^1/2) / 2 + PE
    Total System Jitter (TSJ):  0.070ns
    Discrete Jitter (DJ):       0.123ns
    Phase Error (PE):           0.000ns
Has anyone managed to successfully modify the project ?
I have attached both mhs and twr files.
I have been struggling with it for a while and appreciate any help!
Maciek
