PE Student Edition supports only a single HDL Error In Modelsim
I finally got Modelsim to work with XPS and I can compile (c) in modelsim but when I type s in modelsim I get the following error "PE Student Edition supports only a single HDL".  Yes I am using the student addition but I believe everything was created in VHDL by XPS.  Can anyone give me any pointers?
DeWayne
Re: PE Student Edition supports only a single HDL Error In Modelsim
That is the correct one.
If you look at the section  DDR_SDRAM of MHS, DDR is interfaced using MPMC. The HDL of this core is in Verilog.
You can check trying the simulation by commenting out the DDR SDRAM core.
HTH
Just wondering if you have any Custom Peripheral in Verilog or have MPMC in your design. Some of the hdl in MPMC core are in Verilog.
HTH,
Hem
Nope, I haven't created any of my files just what is created by XPS.
Can you let us know how your MHS looks like ?
Regards.
Is this the correct file?
# Created by Base System Builder Wizard for Xilinx EDK 10.1.02 Build EDK_K_SP2.5
# Fri Aug 15 22:44:58 2008
# Target Board: Xilinx Spartan-3E Starter Board Rev C
# Family: spartan3e
# Device: XC3S500e
# Package: FG320
# Speed Grade: -4
# Processor: microblaze_0
# System clock frequency: 50.00 MHz
# On Chip Memory : 8 KB
# Total Off Chip Memory : 48 MB
# - FLASH = 16 MB
# - DDR_SDRAM = 32 MB
PARAMETER VERSION = 2.1.0
PORT fpga_0_RS232_DCE_RX_pin = fpga_0_RS232_DCE_RX, DIR = I
PORT fpga_0_RS232_DCE_TX_pin = fpga_0_RS232_DCE_TX, DIR = O
PORT fpga_0_RS232_DTE_RX_pin = fpga_0_RS232_DTE_RX, DIR = I
PORT fpga_0_RS232_DTE_TX_pin = fpga_0_RS232_DTE_TX, DIR = O
PORT fpga_0_LEDs_8Bit_GPIO_d_out_pin = fpga_0_LEDs_8Bit_GPIO_d_out, DIR = O, VEC = [0:7]
PORT fpga_0_DIP_Switches_4Bit_GPIO_in_pin = fpga_0_DIP_Switches_4Bit_GPIO_in, DIR = I, VEC = [0:3]
PORT fpga_0_Buttons_4Bit_GPIO_in_pin = fpga_0_Buttons_4Bit_GPIO_in, DIR = I, VEC = [0:3]
PORT fpga_0_FLASH_Mem_OEN_pin = fpga_0_FLASH_Mem_OEN, DIR = O
PORT fpga_0_FLASH_Mem_CEN_pin = fpga_0_FLASH_Mem_CEN, DIR = O, VEC = [0:0]
PORT fpga_0_FLASH_Mem_WEN_pin = fpga_0_FLASH_Mem_WEN, DIR = O
PORT fpga_0_FLASH_emc_ben_gnd_pin = net_gnd, DIR = O
PORT fpga_0_FLASH_Mem_A_pin = fpga_0_FLASH_Mem_A, DIR = O, VEC = [8:31]
PORT fpga_0_FLASH_Mem_DQ_pin = fpga_0_FLASH_Mem_DQ, DIR = IO, VEC = [0:7]
PORT fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O = fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O, DIR = IO
PORT fpga_0_DDR_SDRAM_DDR_Clk_pin = fpga_0_DDR_SDRAM_DDR_Clk, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_Clk_n_pin = fpga_0_DDR_SDRAM_DDR_Clk_n, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_Addr_pin = fpga_0_DDR_SDRAM_DDR_Addr, DIR = O, VEC = [12:0]
PORT fpga_0_DDR_SDRAM_DDR_BankAddr_pin = fpga_0_DDR_SDRAM_DDR_BankAddr, DIR = O, VEC = [1:0]
PORT fpga_0_DDR_SDRAM_DDR_CAS_n_pin = fpga_0_DDR_SDRAM_DDR_CAS_n, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_CE_pin = fpga_0_DDR_SDRAM_DDR_CE, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_CS_n_pin = fpga_0_DDR_SDRAM_DDR_CS_n, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_RAS_n_pin = fpga_0_DDR_SDRAM_DDR_RAS_n, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_WE_n_pin = fpga_0_DDR_SDRAM_DDR_WE_n, DIR = O
PORT fpga_0_DDR_SDRAM_DDR_DM_pin = fpga_0_DDR_SDRAM_DDR_DM, DIR = O, VEC = [1:0]
PORT fpga_0_DDR_SDRAM_DDR_DQS = fpga_0_DDR_SDRAM_DDR_DQS, DIR = IO, VEC = [1:0]
PORT fpga_0_DDR_SDRAM_DDR_DQ = fpga_0_DDR_SDRAM_DDR_DQ, DIR = IO, VEC = [15:0]
PORT fpga_0_Ethernet_MAC_PHY_tx_clk_pin = fpga_0_Ethernet_MAC_PHY_tx_clk, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_rx_clk_pin = fpga_0_Ethernet_MAC_PHY_rx_clk, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_crs_pin = fpga_0_Ethernet_MAC_PHY_crs, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_dv_pin = fpga_0_Ethernet_MAC_PHY_dv, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_rx_data_pin = fpga_0_Ethernet_MAC_PHY_rx_data, DIR = I, VEC = [3:0]
PORT fpga_0_Ethernet_MAC_PHY_col_pin = fpga_0_Ethernet_MAC_PHY_col, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_rx_er_pin = fpga_0_Ethernet_MAC_PHY_rx_er, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_tx_en_pin = fpga_0_Ethernet_MAC_PHY_tx_en, DIR = O
PORT fpga_0_Ethernet_MAC_PHY_tx_data_pin = fpga_0_Ethernet_MAC_PHY_tx_data, DIR = O, VEC = [3:0]
PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ = 50000000
PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 1, SIGIS = RST
BEGIN microblaze
PARAMETER INSTANCE = microblaze_0
PARAMETER C_INTERCONNECT = 1
PARAMETER HW_VER = 7.10.c
PARAMETER C_DEBUG_ENABLED = 1
PARAMETER C_AREA_OPTIMIZED = 1
BUS_INTERFACE DLMB = dlmb
BUS_INTERFACE ILMB = ilmb
BUS_INTERFACE DPLB = mb_plb
BUS_INTERFACE IPLB = mb_plb
BUS_INTERFACE DEBUG = microblaze_0_dbg
PORT MB_RESET = mb_reset
END
BEGIN plb_v46
PARAMETER INSTANCE = mb_plb
PARAMETER HW_VER = 1.03.a
PORT PLB_Clk = sys_clk_s
PORT SYS_Rst = sys_bus_reset
END
BEGIN lmb_v10
PARAMETER INSTANCE = ilmb
PARAMETER HW_VER = 1.00.a
PORT LMB_Clk = sys_clk_s
END
BEGIN lmb_v10
PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
PARAMETER INSTANCE = dlmb_cntlr
PARAMETER HW_VER = 2.10.a
PARAMETER C_BASEADDR = 0x00000000
PARAMETER C_HIGHADDR = 0x00001fff
BUS_INTERFACE SLMB = dlmb
BUS_INTERFACE BRAM_PORT = dlmb_port
END
PARAMETER INSTANCE = ilmb_cntlr
BUS_INTERFACE SLMB = ilmb
BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
PARAMETER INSTANCE = lmb_bram
BUS_INTERFACE PORTA = ilmb_port
BUS_INTERFACE PORTB = dlmb_port
END
BEGIN xps_uartlite
PARAMETER INSTANCE = RS232_DTE
PARAMETER C_BAUDRATE = 9600
PARAMETER C_DATA_BITS = 8
PARAMETER C_ODD_PARITY = 0
PARAMETER C_USE_PARITY = 0
PARAMETER C_SPLB_CLK_FREQ_HZ = 50000000
PARAMETER C_BASEADDR = 0x84000000
PARAMETER C_HIGHADDR = 0x8400ffff
BUS_INTERFACE SPLB = mb_plb
PORT RX = fpga_0_RS232_DTE_RX
PORT TX = fpga_0_RS232_DTE_TX
END
BEGIN xps_uartlite
PARAMETER INSTANCE = RS232_DCE
PARAMETER C_BASEADDR = 0x84020000
PARAMETER C_HIGHADDR = 0x8402ffff
PORT RX = fpga_0_RS232_DCE_RX
PORT TX = fpga_0_RS232_DCE_TX
END
BEGIN xps_gpio
PARAMETER INSTANCE = LEDs_8Bit
PARAMETER C_GPIO_WIDTH = 8
PARAMETER C_IS_DUAL = 0
PARAMETER C_IS_BIDIR = 0
PARAMETER C_ALL_INPUTS = 0
PARAMETER C_BASEADDR = 0x81400000
PARAMETER C_HIGHADDR = 0x8140ffff
PORT GPIO_d_out = fpga_0_LEDs_8Bit_GPIO_d_out
END
BEGIN xps_gpio
PARAMETER INSTANCE = DIP_Switches_4Bit
PARAMETER C_GPIO_WIDTH = 4
PARAMETER C_ALL_INPUTS = 1
PARAMETER C_BASEADDR = 0x81420000
PARAMETER C_HIGHADDR = 0x8142ffff
PORT GPIO_in = fpga_0_DIP_Switches_4Bit_GPIO_in
END
BEGIN xps_gpio
PARAMETER INSTANCE = Buttons_4Bit
PARAMETER C_BASEADDR = 0x81440000
PARAMETER C_HIGHADDR = 0x8144ffff
PORT GPIO_in = fpga_0_Buttons_4Bit_GPIO_in
END
BEGIN xps_mch_emc
PARAMETER INSTANCE = FLASH
PARAMETER HW_VER = 2.00.a
PARAMETER C_MCH_PLB_CLK_PERIOD_PS = 20000
PARAMETER C_NUM_BANKS_MEM = 1
PARAMETER C_MAX_MEM_WIDTH = 8
PARAMETER C_MEM0_WIDTH = 8
PARAMETER C_INCLUDE_DATAWIDTH_MATCHING_0 = 1
PARAMETER C_SYNCH_MEM_0 = 0
PARAMETER C_TCEDV_PS_MEM_0 = 110000
PARAMETER C_TWC_PS_MEM_0 = 110000
PARAMETER C_TAVDV_PS_MEM_0 = 110000
PARAMETER C_TWP_PS_MEM_0 = 70000
PARAMETER C_THZCE_PS_MEM_0 = 35000
PARAMETER C_TLZWE_PS_MEM_0 = 15000
PARAMETER C_MEM0_BASEADDR = 0x85000000
PARAMETER C_MEM0_HIGHADDR = 0x85ffffff
PORT Mem_A = fpga_0_FLASH_Mem_A_split
PORT Mem_DQ = fpga_0_FLASH_Mem_DQ
PORT Mem_OEN = fpga_0_FLASH_Mem_OEN
PORT Mem_WEN = fpga_0_FLASH_Mem_WEN
PORT Mem_CEN = fpga_0_FLASH_Mem_CEN
PORT RdClk = sys_clk_s
END
BEGIN mpmc
PARAMETER INSTANCE = DDR_SDRAM
PARAMETER HW_VER = 4.02.a
PARAMETER C_NUM_PORTS = 1
PARAMETER C_MEM_PARTNO = MT46V16M16-6
PARAMETER C_SPECIAL_BOARD = S3E_STKIT
PARAMETER C_MEM_BANKADDR_WIDTH = 2
PARAMETER C_MEM_DATA_WIDTH = 16
PARAMETER C_MEM_DQS_WIDTH = 2
PARAMETER C_MEM_DM_WIDTH = 2
PARAMETER C_MEM_TYPE = DDR
PARAMETER C_PIM0_BASETYPE = 2
PARAMETER C_MPMC_CLK0_PERIOD_PS = 10000
PARAMETER C_MPMC_BASEADDR = 0x86000000
PARAMETER C_MPMC_HIGHADDR = 0x87ffffff
PARAMETER C_SPLB0_NATIVE_DWIDTH = 32
BUS_INTERFACE SPLB0 = mb_plb
PORT DDR_Clk = fpga_0_DDR_SDRAM_DDR_Clk
PORT DDR_Clk_n = fpga_0_DDR_SDRAM_DDR_Clk_n
PORT DDR_Addr = fpga_0_DDR_SDRAM_DDR_Addr
PORT DDR_BankAddr = fpga_0_DDR_SDRAM_DDR_BankAddr
PORT DDR_CAS_n = fpga_0_DDR_SDRAM_DDR_CAS_n
PORT DDR_CE = fpga_0_DDR_SDRAM_DDR_CE
PORT DDR_CS_n = fpga_0_DDR_SDRAM_DDR_CS_n
PORT DDR_RAS_n = fpga_0_DDR_SDRAM_DDR_RAS_n
PORT DDR_WE_n = fpga_0_DDR_SDRAM_DDR_WE_n
PORT DDR_DM = fpga_0_DDR_SDRAM_DDR_DM
PORT DDR_DQS = fpga_0_DDR_SDRAM_DDR_DQS
PORT DDR_DQ = fpga_0_DDR_SDRAM_DDR_DQ
PORT DDR_DQS_Div_O = fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O
PORT DDR_DQS_Div_I = fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O
PORT MPMC_Clk0 = DDR_SDRAM_mpmc_clk_s
PORT MPMC_Clk90 = DDR_SDRAM_mpmc_clk_90_s
PORT MPMC_Rst = sys_periph_reset
END
BEGIN xps_ethernetlite
PARAMETER INSTANCE = Ethernet_MAC
PARAMETER C_SPLB_CLK_PERIOD_PS = 20000
PARAMETER C_BASEADDR = 0x81000000
PARAMETER C_HIGHADDR = 0x8100ffff
PORT PHY_tx_clk = fpga_0_Ethernet_MAC_PHY_tx_clk
PORT PHY_rx_clk = fpga_0_Ethernet_MAC_PHY_rx_clk
PORT PHY_crs = fpga_0_Ethernet_MAC_PHY_crs
PORT PHY_dv = fpga_0_Ethernet_MAC_PHY_dv
PORT PHY_rx_data = fpga_0_Ethernet_MAC_PHY_rx_data
PORT PHY_col = fpga_0_Ethernet_MAC_PHY_col
PORT PHY_rx_er = fpga_0_Ethernet_MAC_PHY_rx_er
PORT PHY_tx_en = fpga_0_Ethernet_MAC_PHY_tx_en
PORT PHY_tx_data = fpga_0_Ethernet_MAC_PHY_tx_data
END
BEGIN util_bus_split
PARAMETER INSTANCE = FLASH_util_bus_split_0
PARAMETER C_SIZE_IN = 32
PARAMETER C_LEFT_POS = 0
PARAMETER C_SPLIT = 8
PORT Sig = fpga_0_FLASH_Mem_A_split
PORT Out2 = fpga_0_FLASH_Mem_A
END
BEGIN clock_generator
PARAMETER INSTANCE = clock_generator_0
PARAMETER HW_VER = 2.01.a
PARAMETER C_EXT_RESET_HIGH = 1
PARAMETER C_CLKIN_FREQ = 50000000
PARAMETER C_CLKOUT0_FREQ = 50000000
PARAMETER C_CLKOUT0_BUF = TRUE
PARAMETER C_CLKOUT0_PHASE = 0
PARAMETER C_CLKOUT0_GROUP = NONE
PARAMETER C_CLKOUT1_FREQ = 100000000
PARAMETER C_CLKOUT1_BUF = TRUE
PARAMETER C_CLKOUT1_PHASE = 0
PARAMETER C_CLKOUT1_GROUP = DCM0
PARAMETER C_CLKOUT2_FREQ = 100000000
PARAMETER C_CLKOUT2_BUF = TRUE
PARAMETER C_CLKOUT2_PHASE = 90
PARAMETER C_CLKOUT2_GROUP = DCM0
PORT CLKOUT0 = sys_clk_s
PORT CLKOUT1 = DDR_SDRAM_mpmc_clk_s
PORT CLKOUT2 = DDR_SDRAM_mpmc_clk_90_s
PORT CLKIN = dcm_clk_s
PORT LOCKED = Dcm_all_locked
PORT RST = net_gnd
END
BEGIN mdm
PARAMETER INSTANCE = debug_module
PARAMETER HW_VER = 1.00.c
PARAMETER C_MB_DBG_PORTS = 1
PARAMETER C_USE_UART = 1
PARAMETER C_UART_WIDTH = 8
PARAMETER C_BASEADDR = 0x84400000
PARAMETER C_HIGHADDR = 0x8440ffff
BUS_INTERFACE MBDEBUG_0 = microblaze_0_dbg
PORT Debug_SYS_Rst = Debug_SYS_Rst
END
BEGIN proc_sys_reset
PARAMETER INSTANCE = proc_sys_reset_0
PORT Slowest_sync_clk = sys_clk_s
PORT Dcm_locked = Dcm_all_locked
PORT Ext_Reset_In = sys_rst_s
PORT MB_Reset = mb_reset
PORT Bus_Struct_Reset = sys_bus_reset
PORT MB_Debug_Sys_Rst = Debug_SYS_Rst
PORT Peripheral_Reset = sys_periph_reset
END
HTH
I couldn't figure out how to get the comment-out to work so I reran XPS and left out the DDR memory part and that worked.  Is there a way to get the memory interface to compile in VHDL?  When I compiled the memory I tried selecting only VHDL only but that didn't seem to work.  Or will I not be able to use some peripherals?
DeWayne
The MPMC, which is the default memory controller as of EDK 9.x, is only available in mixed VHDL/Verilog. It's a shame, although I like Verilog better than VHDL, but I am in a similar boat as you since my company only has a license for the VHDL version of ModelSim.
Whenever I use a design that uses the MPMC, I have to 'simulate' the design by running it directly on hardware.
I don't know if 10.1 still has the old cores, but EDK 9.1 and 9.2 still had the old DDR memory cores available by enabling the deprecated cores. If that's the case, you may be able to use one of the OPB MCH DDR, and the old Microblaze that still has OPB support.
Hello everyone,
I met an error when I tried to "launch HDL Simulator" after I "Compile Simulation Libraries" successfully.   The errors are shown as follows:
Generating simulator compile script ...
ERROR:EDK:2604 - Unable to locate the precompiled library microblaze_v7_20_a.
   The file
   D:\Xilinx\11.1\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v7_20_a\hdl\vhdl
   \microblaze_types_pkg.vhd is distributed by Xilinx encrypted and will not be
   read by any simulator. Please use compedklib to setup the EDK precompiled
   libraries and provide the path to them using the -E switch.
ERROR:EDK:1172 - Error while creating simulator compile script
make: *** [simulation/behavioral/system_setup.do] Error 1
Done!
Can anyone give me a solution for this? Many thanks!
tarzan
Hi DeWayne,
Disabling the mixed language simulation support in XPS should do the trick.
-XF
