abdulparis
PL Custom Peripheral UART
Does anybody know how we can print PL data on UART (PS7 UARTs or AXI UARTs)? I have a custom PL peripheral and I have some signals that I would like to print through PS. How can I achieve this ?
Thank you very much for your help !
Kind regards,
Abdul
Anonymous
Not applicable
If your custom IP has an AXI interface, then you can send the data to the AXI UART (XIL_OUT32(ADDR, DATA);
The AXI UART, and PS UART only accept data on an AXI interface (This is an embedded IP designed to work in a processor system). If you want to output your data from your custom IP onto the TX/RX pins, then you will need to add the UART protocol to your custom IP, or hack the AXI UART to place your data into the RX FIFO
siktap
Do you have a SDK application with the orint statements? It will be similar to a hello world application.
http://zedboard.org/content/zedboard-sdk-helloworld-example
Sikta
abdulparis
I was not clear in my question. I will try to be more clear this time.
I have a custom peripheral and its output needs to be printed over AXI UART. My question is how can I connect both these IPs together in order to print my data. In other words, how can I generate my peripheral output as RX,TX?
Thank you very much for your answer.
Kind regards,
Abdul
Anonymous
Not applicable
pvenugo
You need to use C code as shown in attached example to print data from/to between custom IP & UART.
This is done thru print statements. If you are writing to preipheral use Xil_Out32 (Address, data) and for reading use Xil_In32 (Address). The example shows same for BRAM <-> AXI UART. Similarly you can repalce BRAM with the custom IP here in C code.
Praveen
s002wjh
either store your output into Bram and use axi_bram control to access from software  or use axi_gpio and connect to your ip.  or DMA, you can't print ur device output directly from hardware, gotta transfer to an axi device for software to read.
