Voyager
Voyager
Packaging IP with optional interfaces
Hi folks,
  I've created a custom IP that has several AXI-Stream interfaces with an
enablement dependency based on a parameter. It works fine, it builds
without errors, but it throws critical warnings for each interface that's not
enabled. I understand the warnings but perhaps there's something I should be doing differently to avoid them.
  The critical warning for each disabled interface is:
[BD 41-1287] Associated interface by name mX_axis_rx not found for clock port /s_axis_clk
  As you see, the interfaces are enabled by the NUM_FIFOS>X expression, and
they have the associated s_axis_clk clock. So when the interface is disabled,
the s_axis_clk throws a critical warning stating there's a clock associated
with a missing interface.
  I guess the clock association should be done after the interface has been
disabled, but I can't see where in the Packager GUI this can be done. Should
it be done in the tcl code? Perhaps in validate_PARAM_VALUE.NUM_FIFOS procedure? Something like:
proc validate_PARAM_VALUE.NUM_FIFOS { PARAM_VALUE.NUM_FIFOS } {
    # Procedure called to validate NUM_FIFOS
  if {PARAM_VALUE.NUM_FIFOS>3}{
    ipx::associate_bus_interfaces -busif m3_axis_rx -clock s_axis_clk -clear [ipx::current_core]
  } else {
    ipx::associate_bus_interfaces -busif m3_axis_rx -clock s_axis_clk [ipx::current_core]
  # <...other interfaces...>
    return true
  Unfortunately, while customizing the IP in IPI, this throws a Tcl error
"::ipgui_ps_sys_ii_dma_mc_0_2_1::validate_PARAM_VALUE.NUM_FIFOS' method. extra
characters after close-brace"
Any ideas?
Thanks in advance,
-Pat
https://tuxengineering.com
