Parser error problem while importing IP
hi,
Parsing XST project file successfully ...
Analyzing HDL source files ...
Analyzing HDL source files successfully ...
HDL language for the peripheral (top level) design unit sample_ip is vhdl ...
WARNING:MDT - Project file C:\demo2\pcores/sample_ip.prj already exists, will be
   overwrite and removed afterward ...
INFO:MDT - Create temparary xst project file: C:\demo2\pcores/sample_ip.prj
Compiling vhdl file
"D:/Xilinx/10.1/EDK/EDK/hw/XilinxProcessorIPLib/pcores/proc_common_v2_00_a/hdl/v
hdl/proc_common_pkg.vhd" in Library proc_common_v2_00_a.
Package <proc_common_pkg> compiled.
Package body <proc_common_pkg> compiled.
Compiling vhdl file
hdl/or_muxcy.vhd" in Library proc_common_v2_00_a.
Entity <or_muxcy> compiled.
Entity <or_muxcy> (Architecture <implementation>) compiled.
Compiling vhdl file
hdl/family_support.vhd" in Library proc_common_v2_00_a.
Package <family_support> compiled.
Package body <family_support> compiled.
Compiling vhdl file
hdl/counter_f.vhd" in Library proc_common_v2_00_a.
Entity <counter_f> compiled.
Entity <counter_f> (Architecture <imp>) compiled.
Compiling vhdl file
hdl/pselect_f.vhd" in Library proc_common_v2_00_a.
Entity <pselect_f> compiled.
Entity <pselect_f> (Architecture <imp>) compiled.
Compiling vhdl file
hdl/or_gate128.vhd" in Library proc_common_v2_00_a.
Entity <or_gate128> compiled.
Entity <or_gate128> (Architecture <imp>) compiled.
Compiling vhdl file
hdl/ipif_pkg.vhd" in Library proc_common_v2_00_a.
Package <ipif_pkg> compiled.
Package body <ipif_pkg> compiled.
Compiling vhdl file
"D:/Xilinx/10.1/EDK/EDK/hw/XilinxProcessorIPLib/pcores/plbv46_slave_single_v1_00
_a/hdl/vhdl/plb_address_decoder.vhd" in Library plbv46_slave_single_v1_00_a.
Entity <plb_address_decoder> compiled.
Entity <plb_address_decoder> (Architecture <IMP>) compiled.
Compiling vhdl file
_a/hdl/vhdl/plb_slave_attachment.vhd" in Library plbv46_slave_single_v1_00_a.
Entity <plb_slave_attachment> compiled.
Entity <plb_slave_attachment> (Architecture <implementation>) compiled.
Compiling vhdl file "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/user_logic.vhd"
in Library sample_ip_v1_00_a.
Entity <user_logic> compiled.
Entity <user_logic> (Architecture <IMP>) compiled.
Compiling vhdl file "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd"
Entity <sample_ip> compiled.
ERROR:HDLParsers:3312 -
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 232.
   Undefined symbol 'SLV64_ARRAY_TYPE'.
ERROR:HDLParsers:1209 -
   SLV64_ARRAY_TYPE: Undefined symbol (last report in this block)
ERROR:HDLParsers:3285 -
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 233. No array
   or record type can be found that has elements of types matching the
   aggregate.
ERROR:HDLParsers:532 -
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 232. Deferred
   constant are allowed only in packages.
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 244.
   Undefined symbol 'INTEGER_ARRAY_TYPE'.
   INTEGER_ARRAY_TYPE: Undefined symbol (last report in this block)
ERROR:HDLParsers:842 -
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 246. The type
   of the element in aggregate does not correspond to any array type.
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 244. Deferred
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 267.
   Undefined symbol 'calc_start_ce_index'.
   calc_start_ce_index: Undefined symbol (last report in this block)
   Undefined symbol 'IPIF_ARD_NUM_CE_ARRAY'.
   IPIF_ARD_NUM_CE_ARRAY: Undefined symbol (last report in this block)
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 267. Deferred
ERROR:HDLParsers:3313 -
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 269.
   Undefined symbol 'USER_SLV_CE_INDEX'.  Should it be: USER_SLV_Cs_INDEX?
   USER_SLV_CE_INDEX: Undefined symbol (last report in this block)
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 269. Deferred
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 284.
   Undefined symbol 'IPIF_ARD_ADDR_RANGE_ARRAY'.
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 285.
   Undefined symbol 'calc_num_ce'.
   calc_num_ce: Undefined symbol (last report in this block)
ERROR:HDLParsers:709 -
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 299.
   plbv46_slave_single is not an entity name
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 302.
   IPIF_ARD_ADDR_RANGE_ARRAY: Undefined symbol (last report in this block)
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 367.
   Undefined symbol 'ipif_Bus2IP_CS'.
   ipif_Bus2IP_CS: Undefined symbol (last report in this block)
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 368.
   Undefined symbol 'ipif_Bus2IP_RdCE'.
   ipif_Bus2IP_RdCE: Undefined symbol (last report in this block)
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 370.
   Undefined symbol 'ipif_Bus2IP_WrCE'.
   ipif_Bus2IP_WrCE: Undefined symbol (last report in this block)
   "C:/demo2/pcores/sample_ip_v1_00_a/hdl/vhdl/sample_ip.vhd" Line 412.
   Undefined symbol 'USER_CE_INDEX'.
   USER_CE_INDEX: Undefined symbol (last report in this block)
ERROR:MDT - Parse Errors encountered in HDL source
WARNING:MDT - Unable to delete temparary project file
   C:\demo2\pcores\sample_ip.prj : 13
how these errors can be removed?
nasim
