Paths and Symbols missing from C++ file properties in Vitis 2019.2
I have set some paths and symbols at the application level in Vitis 2019.2.
These appear in the properties of the application C files the but not the C++ files.
How do I set the paths and symbols for the C++ files?
Re: Paths and Symbols missing from C++ file properties in Vitis 2019.2
Hi @dave74321,
Please try to use a C++ project instead of C project.
Using a C++ project type, all the properties will be populated correctly for all of the C and CPP files.
Best regards,
Abdallah
Hi @dave74321,
Best regards,
Abdallah
