Visitor an2017
Petalinux 2017.1 "Memory read error at 0xB0000000, AXI AP transaction error, DAP status 30000021"
Hardware: zcu102 zu9 es-1
Petalinux 2017.1
Vivado 2016.4 to generate HDF and bitstream.
In the Vivado project, I set added a data device with in the address editor with the following parameters:
  • Slave itnerface: CTL_AXI
  • Base name: reg0
  • Offset Address: 0x00_B000_0000
  • Range: 256M
  • High Address: 0x00_BFFF_FFFF
I can boot with the HDF. However, I cannot access the memory address for the device above. When I run xsdb,
xsdb% mrd -force 0xB0000000
Memory read error at 0xB0000000. AXI AP transaction error, DAP status 30000021
xsdb% targets
1 PS TAP
2 PMU
3 MicroBlaze PMU (Sleeping. No clock)
4 PL
5* PSU
6 RPU
7 Cortex-R5 #0 (Halted)
8 Cortex-R5 #1 (Lock Step Mode)
9 APU
10 Cortex-A53 #0 (Reset Catch, EL3(S)/A64)
11 Cortex-A53 #1 (Running)
12 Cortex-A53 #2 (Cannot resume. APB AP transaction error, DAP status 30000021, EL0(S)/A64)
13 Cortex-A53 #3 (Running)
xsdb%
What could cause this?
Re: Petalinux 2017.1 "Memory read error at 0xB0000000, AXI AP transaction error, DAP status 30000021"
Hi @an2017,
  • your IP could be not AXI compliant. Try with another IP (ex GPIO IP)
  • the PSU could be stuck
  • and this could be a reason:
Florent
Can you power cycle. Then target the PSU, source psu_init.tcl, psu_init, psu_post_config,
psu_ps_pl_isolation_removal
psu_ps_pl_reset_config
Then target the cortexa53 #0 and try again
Visitor an2017
I power cycled the board. Re-booted it via jtag and ran the following commands in xsdb:
connect
targets
source psu_init.tcl
targets 10 mrd -force 0xB0000000
It didn't read, but I got a new error:
xsdb% connect
attempting to launch hw_server
****** Xilinx hw_server v2016.4
  **** Build date : Dec 14 2016-22:55:00
    ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
awk: symbol lookup error: awk: undefined symbol: mpfr_z_sub
tcfchan#0
xsdb% Info: Cortex-A53 #2 (target 12) Stopped at 0xfffea0f8 (Reset Catch)
targets
  1  PS TAP
     2  PMU
     4  PL
  5  PSU
     6  RPU
     9  APU
       10  Cortex-A53 #0 (Running)
       12  Cortex-A53 #2 (Reset Catch, EL3(S)/A64)
xsdb% source psu_init.tcl
xsdb% targets 5
xsdb% psu_ps_pl_isolation_removal
xsdb% psu_ps_pl_reset_config
xsdb% targets
  1  PS TAP
     2  PMU
     4  PL
  5* PSU
     6  RPU
     9  APU
xsdb% target 10
Memory read error at 0xB0000000. MMU fault at VA 0xB0000000. Translation fault, first level
xsdb% targets
  1  PS TAP
     2  PMU
     4  PL
  5  PSU
     6  RPU
     9  APU
       10* Cortex-A53 #0 (Running)
Your programming the PL too?
Do this after connect
fpga -f download.bit
Visitor an2017
Yes, I'm programming the FPGA. I'm using "petalinux-build -v --jtag --fpga --bitstream..."
What do those commands do?
Visitor an2017
(1) The IP block connect to the AXI Bus is the AXI Protocol Convertor and this data path setup has worked correctly on previous iterations of design.
(2) How could I check/fix if the PSU is stuck?
(3) The core goes into that state AFTER trying to do the "mrd" and then gets stuck. Have the power cycle the board in order to fix it.
