bhuelsen
Petalinux 2017.2 rootfs: opencv / libmali issue
Hi everyone,
I would like to install opencv to the root file system of my petalinux project.
I am using petalinux 2017.2.
I enabled the petalinux libs as following:
benjaminh@memory-lab-pc:~/embedded_development/ultrazed_repo/software/petalinux_build$ petalinux-build --component rootfs
[INFO] building rootfs
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image -c do_image_complete
Loading cache: 100% |############################################| Time: 0:00:00
Loaded 3233 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:02
Parsing of 2446 .bb files complete (2412 cached, 34 parsed). 3236 targets, 224 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:08
Checking sstate mirror object availability: 100% |###############| Time: 0:00:09
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Failed to fetch URL git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master, attempting MIRRORS if available
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-cZ6Ffrtu5R"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export PATH="/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/plnx_aarch64/usr/bin/crossscripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/bitbake/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-uclibc:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-musl:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/utils:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin/unexport:/home/benjaminh/petalinux_2017_2/tools/hsm/bin:/home/benjaminh/petalinux_2017_2/tools/webtalk/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/opt/xlx_2017_2/Vivado/2017.2/bin:/opt/xlx_2017_2/Vivado_HLS/2017.2/bin:/opt/xlx_2017_1/DocNav:/opt/xlx_2017_2/SDK/2017.2/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/arm/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-linux/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-none/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/tps/lnx64/cmake-3.3.2/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/dtc:/home/benjaminh/bin:/home/benjaminh/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/benjaminh"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git --progress failed with exit code 128, output:
Cloning into bare repository '/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git'...
fatal: unable to access 'https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git/': Couldn't resolve host 'gitenterprise.xilinx.com'
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master'. Unable to fetch URL from any source.
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/work/aarch64-xilinx-linux/libmali-xlnx/r7p0-00rel0-r0/temp/log.do_fetch.20711
ERROR: Task (/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb:do_fetch) failed with exit code '1'
WARNING: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Failed to fetch URL http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz, attempting MIRRORS if available
ERROR: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-cZ6Ffrtu5R"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export PATH="/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/plnx_aarch64/usr/bin/crossscripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/bitbake/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-uclibc:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-musl:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/utils:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin/unexport:/home/benjaminh/petalinux_2017_2/tools/hsm/bin:/home/benjaminh/petalinux_2017_2/tools/webtalk/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/opt/xlx_2017_2/Vivado/2017.2/bin:/opt/xlx_2017_2/Vivado_HLS/2017.2/bin:/opt/xlx_2017_1/DocNav:/opt/xlx_2017_2/SDK/2017.2/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/arm/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-linux/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-none/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/tps/lnx64/cmake-3.3.2/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/dtc:/home/benjaminh/bin:/home/benjaminh/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/benjaminh"; /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads 'http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz' --progress=dot -v failed with exit code 4, output:
--2017-07-26 15:37:24--  http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz
Resolving malideveloper.arm.com... 23.14.95.88, 23.14.95.96
Connecting to malideveloper.arm.com|23.14.95.88|:80... connected.
HTTP request sent, awaiting response... 504 Gateway Time-out
Retrying.
--2017-07-26 15:37:43--  (try: 2)  http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz
Giving up.
ERROR: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz'. Unable to fetch URL from any source.
ERROR: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/work/plnx_aarch64-xilinx-linux/kernel-module-mali/r7p0-00rel0-r0/temp/log.do_fetch.20722
ERROR: Task (/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/mali/kernel-module-mali.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3420 tasks of which 3418 didn't need to be rerun and 2 failed.
Summary: 2 tasks failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 6 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build rootfs
As you can see, it failed to build the rootfs.
It attemps to fetch the libmali-xlxnx-r7p0-00rel0-r0 kernel module but failes, because
the server git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git is down.
@xilinx: Is there a plan to solve that problem? Or is there a suitable workaround to use opencv in petalinux 2017.2?
Benjamin
vineethc
petalinux-config
    --> Yocto Settings  --->
                 --->  YOCTO SOURCE MIRROR URL ( choose external path )
                                   -->  EXTERNAL PATH
                                Enter -->  http://www.petalinux.xilinx.com/sswreleases/rel-v2017.2/downloads
cyrius
Hello everyone,
   I have the same problem.
   Does someone has the solution ?
Thx.
Same problem here!
Any body any solution?
vineethc
petalinux-config
                                   -->  EXTERNAL PATH
ibaie
Hi @bhuelsen
It looks like there are two issues in your problem:
  1. Mali userspace driver fetch issue (URL to private gitenterprise location)
  2. Kernel Mali module fetch issue (URL to non valid ARM location)
Reviewing the github repository it looks like these issue has been fixed for future releases (i.e. https://github.com/Xilinx/meta-xilinx/commit/4afe9d6ca35ddea3be84e93f4a30933bfb034b4c)
As a workaround can you try to set the Yocto external Mirror with the following URL?
Ibai
bhuelsen
Hi @ibaie,
thanks for your reply.
I performed following steps:
-> I replaced the URL in the kernel-module-mali.bb file according to issue 2)
-	http://malideveloper.arm.com/downloads/drivers/DX910/${PV}/DX910-SW-99002-${PV}.tgz \
+	https://developer.arm.com/-/media/Files/downloads/mali-drivers/kernel/mali-utgard-gpu/DX910-SW-99002-${PV}.tgz \
-> and set the external source mirror path as you described.
For better understanding here the full terminal output:
Parsing recipes: 100% |###############################################################| Time: 0:01:11
Parsing of 2446 .bb files complete (0 cached, 2446 parsed). 3236 targets, 224 skipped, 0 masked, 0 errors.
Initialising tasks: 100% |############################################################| Time: 0:00:07
Checking sstate mirror object availability: 100% |####################################| Time: 0:00:19
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-B2Ix111E5p"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export PATH="/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/plnx_aarch64/usr/bin/crossscripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/bitbake/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-uclibc:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-musl:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/utils:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin/unexport:/home/benjaminh/petalinux_2017_2/tools/hsm/bin:/home/benjaminh/petalinux_2017_2/tools/webtalk/bin:/opt/xlx_2017_2/Vivado/2017.2/bin:/opt/xlx_2017_2/Vivado_HLS/2017.2/bin:/opt/xlx_2017_1/DocNav:/opt/xlx_2017_2/SDK/2017.2/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/arm/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-linux/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-none/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/tps/lnx64/cmake-3.3.2/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/dtc:/home/benjaminh/bin:/home/benjaminh/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/benjaminh"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git --progress failed with exit code 128, output:
ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/work/aarch64-xilinx-linux/libmali-xlnx/r7p0-00rel0-r0/temp/log.do_fetch.28841
NOTE: Tasks Summary: Attempted 3403 tasks of which 3399 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
The URL issue to a non valid ARM location seems to be fixed
But it still attempts to fetch libmali-xlnx-r7p0-00rel0-r0 from the private URL:
How can I fix that?
vineethc
Hi ,
which file you are changing ?
through xilinx  mali is through meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb
bhuelsen
I've changed <PETA_LINUX_INSTALL_DIR>/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/mali/kernel-module-mali.bb
vineethc
vineethc
http://xkb/Pages/69/69564.aspx
njozwiak
Hi all,
I know this issue is marked as closed, but I wanted to reopen it as I am having the exact same issue and the URL marked as the external mirror in the solution does not appear to be valid anymore. Did the external path change?
vineethc
njozwiak
That fixed it. Thanks
