07-26-2017 08:56 AM
Hi everyone,
I would like to install opencv to the root file system of my petalinux project.
I am using petalinux 2017.2.
I enabled the petalinux libs as following:
benjaminh@memory-lab-pc:~/embedded_development/ultrazed_repo/software/petalinux_build$ petalinux-build --component rootfs [INFO] building rootfs [INFO] sourcing bitbake INFO: bitbake petalinux-user-image -c do_image_complete Loading cache: 100% |############################################| Time: 0:00:00 Loaded 3233 entries from dependency cache. Parsing recipes: 100% |##########################################| Time: 0:00:02 Parsing of 2446 .bb files complete (2412 cached, 34 parsed). 3236 targets, 224 skipped, 0 masked, 0 errors. NOTE: Resolving any missing task queue dependencies Initialising tasks: 100% |#######################################| Time: 0:00:08 Checking sstate mirror object availability: 100% |###############| Time: 0:00:09 NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks WARNING: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Failed to fetch URL git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master, attempting MIRRORS if available ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-cZ6Ffrtu5R"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export PATH="/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/plnx_aarch64/usr/bin/crossscripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/bitbake/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-uclibc:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-musl:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/utils:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin/unexport:/home/benjaminh/petalinux_2017_2/tools/hsm/bin:/home/benjaminh/petalinux_2017_2/tools/webtalk/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/opt/xlx_2017_2/Vivado/2017.2/bin:/opt/xlx_2017_2/Vivado_HLS/2017.2/bin:/opt/xlx_2017_1/DocNav:/opt/xlx_2017_2/SDK/2017.2/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/arm/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-linux/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-none/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/tps/lnx64/cmake-3.3.2/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/dtc:/home/benjaminh/bin:/home/benjaminh/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/benjaminh"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git --progress failed with exit code 128, output: Cloning into bare repository '/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git'... fatal: unable to access 'https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git/': Couldn't resolve host 'gitenterprise.xilinx.com' ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master'. Unable to fetch URL from any source. ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Function failed: base_do_fetch ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/work/aarch64-xilinx-linux/libmali-xlnx/r7p0-00rel0-r0/temp/log.do_fetch.20711 ERROR: Task (/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb:do_fetch) failed with exit code '1' WARNING: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Failed to fetch URL http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz, attempting MIRRORS if available ERROR: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-cZ6Ffrtu5R"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export PATH="/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/plnx_aarch64/usr/bin/crossscripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/bitbake/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-uclibc:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-musl:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/utils:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin/unexport:/home/benjaminh/petalinux_2017_2/tools/hsm/bin:/home/benjaminh/petalinux_2017_2/tools/webtalk/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/opt/xlx_2017_2/Vivado/2017.2/bin:/opt/xlx_2017_2/Vivado_HLS/2017.2/bin:/opt/xlx_2017_1/DocNav:/opt/xlx_2017_2/SDK/2017.2/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/arm/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-linux/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-none/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/tps/lnx64/cmake-3.3.2/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/dtc:/home/benjaminh/bin:/home/benjaminh/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/benjaminh"; /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads 'http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz' --progress=dot -v failed with exit code 4, output: --2017-07-26 15:37:24-- http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz Resolving malideveloper.arm.com... 23.14.95.88, 23.14.95.96 Connecting to malideveloper.arm.com|23.14.95.88|:80... connected. HTTP request sent, awaiting response... 504 Gateway Time-out Retrying. --2017-07-26 15:37:43-- (try: 2) http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz Connecting to malideveloper.arm.com|23.14.95.88|:80... connected. HTTP request sent, awaiting response... 504 Gateway Time-out Giving up. ERROR: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'http://malideveloper.arm.com/downloads/drivers/DX910/r7p0-00rel0/DX910-SW-99002-r7p0-00rel0.tgz'. Unable to fetch URL from any source. ERROR: kernel-module-mali-r7p0-00rel0-r0 do_fetch: Function failed: base_do_fetch ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/work/plnx_aarch64-xilinx-linux/kernel-module-mali/r7p0-00rel0-r0/temp/log.do_fetch.20722 ERROR: Task (/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/mali/kernel-module-mali.bb:do_fetch) failed with exit code '1' NOTE: Tasks Summary: Attempted 3420 tasks of which 3418 didn't need to be rerun and 2 failed. Summary: 2 tasks failed: /home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb:do_fetch /home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/mali/kernel-module-mali.bb:do_fetch Summary: There were 2 WARNING messages shown. Summary: There were 6 ERROR messages shown, returning a non-zero exit code. ERROR: Failed to build rootfs benjaminh@memory-lab-pc:~/embedded_development/ultrazed_repo/software/petalinux_build$
As you can see, it failed to build the rootfs.
It attemps to fetch the libmali-xlxnx-r7p0-00rel0-r0 kernel module but failes, because
the server git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git is down.
@xilinx: Is there a plan to solve that problem? Or is there a suitable workaround to use opencv in petalinux 2017.2?
Benjamin
07-28-2017 01:56 AM
petalinux-config
--> Yocto Settings --->
---> YOCTO SOURCE MIRROR URL ( choose external path )
--> EXTERNAL PATH
Enter --> http://www.petalinux.xilinx.com/sswreleases/rel-v2017.2/downloads
07-26-2017 01:36 PM
Hello everyone,
I have the same problem.
Does someone has the solution ?
Thx.
07-27-2017 02:15 PM
Same problem here!
Any body any solution?
07-28-2017 01:56 AM
petalinux-config
--> EXTERNAL PATH
07-28-2017 02:33 AM
Hi @bhuelsen
It looks like there are two issues in your problem:
Reviewing the github repository it looks like these issue has been fixed for future releases (i.e. https://github.com/Xilinx/meta-xilinx/commit/4afe9d6ca35ddea3be84e93f4a30933bfb034b4c)
As a workaround can you try to set the Yocto external Mirror with the following URL?
07-31-2017 01:48 AM
Hi @ibaie,
thanks for your reply.
I performed following steps:
-> I replaced the URL in the kernel-module-mali.bb file according to issue 2)
- http://malideveloper.arm.com/downloads/drivers/DX910/${PV}/DX910-SW-99002-${PV}.tgz \ + https://developer.arm.com/-/media/Files/downloads/mali-drivers/kernel/mali-utgard-gpu/DX910-SW-99002-${PV}.tgz \
-> and set the external source mirror path as you described.
For better understanding here the full terminal output:
benjaminh@memory-lab-pc:~/embedded_development/ultrazed_repo/software/petalinux_build$ petalinux-build --component rootfs [INFO] building rootfs [INFO] sourcing bitbake INFO: bitbake petalinux-user-image -c do_image_complete Parsing recipes: 100% |###############################################################| Time: 0:01:11 Parsing of 2446 .bb files complete (0 cached, 2446 parsed). 3236 targets, 224 skipped, 0 masked, 0 errors. NOTE: Resolving any missing task queue dependencies Initialising tasks: 100% |############################################################| Time: 0:00:07 Checking sstate mirror object availability: 100% |####################################| Time: 0:00:19 NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks WARNING: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Failed to fetch URL git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master, attempting MIRRORS if available ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-B2Ix111E5p"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export PATH="/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/plnx_aarch64/usr/bin/crossscripts:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/scripts:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/core/bitbake/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/sbin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-uclibc:/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux-musl:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/utils:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin/unexport:/home/benjaminh/petalinux_2017_2/tools/hsm/bin:/home/benjaminh/petalinux_2017_2/tools/webtalk/bin:/opt/xlx_2017_2/Vivado/2017.2/bin:/opt/xlx_2017_2/Vivado_HLS/2017.2/bin:/opt/xlx_2017_1/DocNav:/opt/xlx_2017_2/SDK/2017.2/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/arm/lin/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_be/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-linux/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/aarch64/lin/aarch64-none/bin:/opt/xlx_2017_2/SDK/2017.2/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xlx_2017_2/SDK/2017.2/tps/lnx64/cmake-3.3.2/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/common/petalinux/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi-r5/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblaze-xilinx-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-none-eabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/gcc-arm-linux-gnueabi/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-none-elf/bin:/home/benjaminh/petalinux_2017_2/tools/linux-i386/aarch64-linux-gnu/bin:/home/benjaminh/embedded_development/ultrazed_repo/software/dtc:/home/benjaminh/bin:/home/benjaminh/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/benjaminh"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git --progress failed with exit code 128, output: Cloning into bare repository '/home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/downloads/git2/gitenterprise.xilinx.com.Graphics.mali400-xlnx-userspace.git'... fatal: unable to access 'https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git/': Couldn't resolve host 'gitenterprise.xilinx.com' ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master'. Unable to fetch URL from any source. ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Function failed: base_do_fetch ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/ultrazed_repo/software/petalinux_build/build/tmp/work/aarch64-xilinx-linux/libmali-xlnx/r7p0-00rel0-r0/temp/log.do_fetch.28841 ERROR: Task (/home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb:do_fetch) failed with exit code '1' NOTE: Tasks Summary: Attempted 3403 tasks of which 3399 didn't need to be rerun and 1 failed. Summary: 1 task failed: /home/benjaminh/petalinux_2017_2/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb:do_fetch Summary: There was 1 WARNING message shown. Summary: There were 3 ERROR messages shown, returning a non-zero exit code. ERROR: Failed to build rootfs benjaminh@memory-lab-pc:~/embedded_development/ultrazed_repo/software/petalinux_build$
The URL issue to a non valid ARM location seems to be fixed
But it still attempts to fetch libmali-xlnx-r7p0-00rel0-r0 from the private URL:
How can I fix that?
07-31-2017 10:52 AM
Hi ,
which file you are changing ?
through xilinx mali is through meta-xilinx/recipes-graphics/libgles/libmali-xlnx_git.bb
08-01-2017 01:56 AM
I've changed <PETA_LINUX_INSTALL_DIR>/components/yocto/source/aarch64/layers/meta-xilinx/recipes-graphics/mali/kernel-module-mali.bb
09-19-2017 07:28 AM
09-25-2017 08:33 PM
http://xkb/Pages/69/69564.aspx
10-25-2017 12:52 PM
Hi all,
I know this issue is marked as closed, but I wanted to reopen it as I am having the exact same issue and the URL marked as the external mirror in the solution does not appear to be valid anymore. Did the external path change?
10-25-2017 06:52 PM
http://petalinux.xilinx.com/sswreleases/rel-v2017.2/downloads this url will work
http://www.petalinux.xilinx.com/sswreleases/rel-v2017.2/downloads will not work
10-26-2017 10:25 AM
That fixed it. Thanks
