mishuk
Petalinux 2017.4 boot from SD with ext4 rootfs
currently I use Digilent/Zedboard with Petalinux 2017.2.
As noted in "Configuring SD Card ext filesystem Boot" section of "PetaLinux Tools
Documentation. Reference Guide" I change Image Packaging Configuration to SD card through running petalinux-config.  But!   No changes appear in file "<plnx-proj-root>/components/plnx_workspace/device-tree-generatio
n/system-conf.dtsi" as expected.
Furthermore, I manually added "root=/dev/mmcblk0p2 rw rootwait" to   "<plnx-proj-root>/components/plnx_workspace/device-tree-generation/system-conf.dtsi" and upload BOOT.bin and image.ub to SD card.  In that case Linux kernel stops on "Waiting for root device /dev/mmcblk0p2..."
What am I doing wrong?
Please, redirect me to appropriate forum if i have chosen an improper one.
Tags (3)
madhu.mami60
Hi @mishuk
I think the issue lie behind the Card Detect. If the Card detect is not high, it will keep on wait for the SD card. Check the Vivado design for CD.
Madhu
madhu.mami60
Hi @mishuk
Madhu
vineethc
never edit auto generated files , for user over riding, put them in project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi and over ride the node.
mishuk
Thank you for your advise!
