mutt1
Petalinux-create @2017.1 can't find package xsdb
so Petalinux-create -v returns error "can't find package xsdb" but at prompt "which xsdb" returns /opt/xilinx/Vivado/2017.1/bin and xsdb starts.
can anyone suggest why petalinux-create fails in this manner?
Matt
stephenm
Not sure why the bitbake cant find the xsdb, but you could try update the build\conf\plnxtoo.conf with this info:
EXTERNAL_TOOLCHAIN_microblaze = "/opt/Xilinx/SDK/2017.1/microblaze/linux_toolchain/lin64_le"
XILINX_SDK_TOOLCHAIN = "/opt/Xilinx/SDK/2017.1"
mutt1
thanks for putting me on the right path, looking closer at the reason why those files don't exist I think there is something missing from my tools .
the helpful message on source /opt/petalinux/settings.sh
environment: line 314: ((: 10#15~rc1 > 10#3: syntax error in expression (error token is "~rc1 > 10#3")
environment: line 318: ((: 10#15~rc1 < 10#3: syntax error in expression (error token is "~rc1 < 10#3")
environment: line 314: ((: 10#29b: value too great for base (error token is "10#29b")
environment: line 318: ((: 10#29b: value too great for base (error token is "10#29b")
unfortunately petalinux-env-check is binary so I can't see what is missing.
mutt1
I have also checked on all the packages listed in UG1144. They are all installed, and the only large difference in version is that of gcc v7 installed vs gcc v4.8 required. However I don't believe gcc plays a part in petalinux-config but might I guess fail the check on tools. That said, I know gcc 5.5 works just fine.
fpgastudent
Did you manage to solve this problem?
