Petalinux install problems
I wanted to install the Petalinux tools in Ubuntu 18.04
First I noticed the installer (run file) is not executable and UG1144 mentions:
For example: To install PetaLinux tools under /opt/pkg/petalinux/2019.1:
$ mkdir -p /opt/pkg/petalinux/2019.1
$ ./petalinux-v2019.1-final-installer.run /opt/pkg/petalinux/2019.1
Note: Do not change the installer permissions to CHMOD 775 as it can cause BitBake errors
So how can I run it? I changed it to 754 and ran it but came with an error "cannot extract installer"
Could it be related to that I downloaded the installer to a windows machine then moved it to a VM with Linux?
Participant sarahleony
Re: Petalinux install problems
I also came across this problem and the info in this link fixed it for me:
https://blog.lazy-evaluation.net/posts/linux/petalinux-v2019.1-ubuntu-18.04.html
Hi @satguy,
Could you please check if you have installed all the required packages as mentioned in UG1144.
The error you get could be related to a missing package, please refer to this thread.
Abdallah
Yes, I ran:
sudo apt-get install -y gcc git make net-tools libncurses5-dev tftpd zlib1g-dev libssl-dev flex
bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo
zlib1g-dev gcc-multilib build-essential -dev zlib1g:i386 screen pax gzip
same as in UG1144
Scholar watari
Hi @satguy
I guess it seems dash issue.
Would you run the following command to install petalinux ?
$ bash ./petalinux-v2019.1-final-installer.run /opt/pkg/petalinux/2019.1
As mentioned in this thread, have you double checked it you have installed the gawk package?
Abdallah
@watari
yes, I did that
Thanks to the solution provided I could finally install it.
Weird that a problem from 2016 is not updated in the docs by 2019...
There was this message during the install, I wonder if I got the installer corrupted, or is something I can ignore or not:
INFO: Checking installation environment requirements...
WARNING: This is not a supported OS
INFO: Checking free disk space
INFO: Checking installed tools
environment: line 305: ((: 10#30+ > 10#24: syntax error: operand expected (error token is "> 10#24")
environment: line 309: ((: 10#30+ < 10#24: syntax error: operand expected (error token is "< 10#24")
INFO: Checking installed development libraries
INFO: Checking network and other services
INFO: Checking installer checksum...
INFO: Extracting PetaLinux installer...
LICENSE AGREEMENTS
