moraali
Please Help:- Pressed Push Button , But LED does not light up.
Good morning ,
   I am using EDK 9.2. Based on the coding below, when I pressed the push button, output appeared in the hyperterminal but does not light up the LED. The ucf file is correct. What should I do to rectify this problem, in such when I push the button , the partucilar LED should Light up ?
#include "xparameters.h"
#include "xgpio.h"
#include "xutil.h"
int main (void)
   XGpio led,Push;
   int push_check1, push_check=0;
   xil_printf("-- Entering main() --\r\n");
   XGpio_Initialize(&led,XPAR_LEDS_4BIT_DEVICE_ID);
   XGpio_Initialize(&Push,XPAR_PUSH_BUTTONS_5BIT_DEVICE_ID);
   XGpio_SetDataDirection(&led,1,0x0);
   XGpio_SetDataDirection(&Push,1,0xffffffff);
   xil_printf("Press center push button to exit\r\n");
   xil_printf("Any other to see corresponding LED turn ON\r\n");
   push_check = XGpio_DiscreteRead(&Push,1);
   while(1)
      push_check1 = XGpio_DiscreteRead(&Push,1);
      if(push_check1 != push_check)
        push_check=push_check1;
        if(push_check)
        xil_printf("Push buttons status %0x\r\n", push_check1);
    if(push_check==0x10)
       break;
    XGpio_DiscreteWrite(&led,1,push_check); // Should light up the LED. But it does not.
   xil_printf("-- Exiting main() --\r\n");
   return 0;
