Possible to bit level access in XGpio
Plz help me whether it is possibe......
Q1.
Weather it is possible to set or clear single bit in XGpio register ?
just like
#define led0        0
#define led1        1
#define led2         2
main()
// to ON led0 and led1
XGpio_DiscreteSet(&leds, led0 | led1);
// to ON led1 and led2
XGpio_DiscreteSet(&leds, led1 | led2);
// to OFF led0, led1 and led2
XGpio_DiscreteClear(&leds, led0 | led1 |led2);
thanks in advance
umer
yes, you can set or clear single bits in the xgpio register, but it doesn't look like you can just call those functions as you have specified. Review the xgpio_extra.c source code found in the C:\Xilinx\12.3\ISE_DS\EDK\sw\XilinxProcessorIPLib\drivers\gpio_v3_00_a\src to get an idea of how the functions actually work.
For example, the function is as follows:
void XGpio_DiscreteSet(XGpio * InstancePtr, unsigned Channel, u32 Mask)
So first, you will need three values passed into the function.  Second, the u32 Mask, should be something like 0x01, or 0x0001, or whatever the length of GPIO you have specified, so I'm not sure that the way you have the code written will correctly function.  You can review some examples in the C:\Xilinx\12.3\ISE_DS\EDK\sw\XilinxProcessorIPLib\drivers\gpio_v3_00_a\examples folder. looks like xgpio_example.c might be the best example for discreteset to get started with.
