Possible values for interrupt_rtl and reset_rtl interface parameters in "Create and Package IP" dialog
in the "Create an Package IP..." dialog I have added an interrupt_rtl and an reset_rtl interface. After adding the interfaces I get the following two warnings:
"[IP_Flow 19-3160] Bus Interface 'data_irq (Data ready IRQ signal)': SENSITIVITY bus parameter is missing."
"[IP_Flow 19-3159] Bus Interface 'axi_rst_n (Reset signal to SSRAM interface)': POLARITY bus parameter is missing."
Where can I find the possible parameter values for these parameters (or better a list about all parameters for all interfaces supported by Vivado)?
Martin
Re: Possible values for interrupt_rtl and reset_rtl interface parameters in "Create and Package IP" dialog
These properties can be specified through the property window of that particluar pin/net in the Vivado GUI as shown below
Achutha
