Printing Hello World
I am new to Xilinx Sdk and is working on Zynq 7010 Board. I started with creating an application and after adding a SDK Terminal. I get a warning as shown in the picture attached.
I ignore the warning but then I don't see 'Hello World' Print on my Console.
Hi @vishav26,
To see the output you would need to connect the board using the uart connector and use an UART terminal. I usually use tera term for this.
Florent
Florent
Thanks for the answer. What about the warning? This morning I started my program and I get an additional warning now. Also I have installed Tera term. I ignore the warning. But I don't see any output on Tera term. Both screenshots are attached.
Hi @vishav26,
You might want to configure your zynq in vivado first before using SDK by following UG940. This will remove the warning about the wrong device.
And this should be the issue about why you are not seeing any output on the UART. You board is probably not using the same PS pins as the ZC702.
What is the board you are using? Is it a custom board?
Florent
Florent
I will follow the link you have provided it to me.
I am using the board Z-7010 AP SoC.
I am working on Vivado 2017.3 now and I am not sure which board I should select. The picture of the board that I am working on is attached. Thanks for your help.
Hi @vishav26,
You are using a ZYBO board. This board is not included into vivado by default. You need to add the board files to vivado.
Follow the tutorial from Digilent website to know how to install the board files.
Florent
Florent
Thanks for the support.
I followed UG940 document and proceeded the same way as told. However I am getting some critical warnings. I have ignored it for now but may I know what is it? Attached is the screenshot.
Hi @vishav26,
You can ignore these warnings. They are more if you were designing your own board.
As you are using a zybo, you know the DDR will be working.
Just a check: did you create the project with the ZYBO as target?
Regrads,
Florent
Florent
I have selected Zybo Z010 as the board. Is that what you mean by ZYBO as target?
Hi @vishav26,
Yes this is what I mean. Let me know if you can see the hello world now.
Florent
Florent
I am following UG940 and I am stuck on the following point:
The first image attached is from UG940 Tutorial. So I should get the same screen when I start my SDK.
The second image shows mySDK screen and I don't get the option of hardware platform specified by UG940. What should I do?
Vishav
Hi @vishav26
Did you launched SDK from vivado? This is important to launch it this way, because it will create the HW platform from the exported hardware (hdf).
If you did so, try to delete your full SDK workspace and try again to export/launch SDK from vivado.
Florent
