Printing messages from fsbl
How do I print log messages from FSBL?
I have seen ps7_init.c and pc7_init.h files(generated when I create fsbl) having xil_printf statements. But these statements  are commented. When I uncommented it , the fsbl.elf wont form.
I even tried including xil_printf.h, but even now fsbl is not generated.  fsbl is generated only when xil_printf(,...)  are commented in the file ps7_init.c.
Why it is happening ? How to correctly print messages from fsbl?
Re: Printing messages from fsbl
FSBL having debug prints enabled. #define FSBL_DEBUG_INFO in fsbl_debug.h
--Hem
Thanks for your reply . I have tried editing fsbl_debug.h file but this file is generated after fsbl.elf file.
I have generated fsbl.elf using SDK and i found that fsbl_debug.h is generated along with fsbl.elf.
Where can i find fsbl_debug.h other than the folders containing fsbl.elf so that i can edit it and then generate fsbl.elf.
The FSBL application is available at $SDK_2013.3_Install\sw\lib\sw_apps\fsbl\src
For 2014.1 then you need to go to SDK_2014.1/data/embeddedsw/lib/sw_apps/zynq_fsbl
--Hem
I have made changes in fsbl_debug.h file as per guided by you. I have introduced some xil_printf() statements in the ps7_init.c file and i am able to built .elf file , BOOT.BIN file using .elf file.
Now , when i am booting it in flash , some unrecognised characters are appearing on the terminal and it is also not booting upto the end.
I want to printout my own statements using xil_printf by introducing these statements in ps7_init.c file so that i can see them on terminal. I have also used printf() in place of xil_print() but still i am not able to print any message on terminal .
Please suggest
What are the messages seen on the console? Are you sure that the baud rate of the console is set properly?
Would that be possible to generate the BOOT.bin using some another ELF?
--Hem
The following screenshot shows the weared characters I am getting:
I just put one xil_printf here:
int
ps7_init()
  // Get the PS_VERSION on run time
  unsigned long si_ver = ps7GetSiliconVersion ();
  int pcw_ver = 0;
  xil_printf ("\n PCW Silicon Version : %d.0", si_ver);
 The file ps7_int.c is attached here with also.
I am sure baud rate is correct. Also BOOT.bin is generated with other fsbls where no xil_printf is uncommented.
(I observed that xil_print is commented by default)
Scholar sampatd
Are you booting from NAND flash?
If so, make sure that the boot image is put to the fist 128MB in NAND, the BootRom only searches a limited address.
sorry I forgot to attach the ps7_init.c file.
here it is:
The current Screenshot is from SD card. I understand fsbl 's ps7_init is independent of the boot media. Am I right?
I just made BOOT.BIN using the fsbl, download.bit and uboot. and put oit in sd card. The idea is just to see if something gets on console from ps7_init file or not.
I have attached ps7_init file above
That character display looks a lot like a baud rate or bit count mismatch.  Are you sure your hardware and your terminal are speaking the same baud, bits, stop and parity?
TomT...
Thanks for your reply. I am sure what I am doing in teraterminal , but could you please guide me how do check these settings in my board ?
Scholar sampatd
There is actually no need to change any of the FSBL source files or header files to include the FSBL compilation flags.
Compilation flags can be set using the C/C++ settings in SDK FSBL project, as shown below:
Can you try setting these compilation flags and check the prints?
@sampatd
When I added FSBL_DEBUG_INFO,
I got following error during compilation:
'Invoking: ARM gcc compiler'
arm-xilinx-eabi-gcc -Wall -O0 -g3 FSBL_DEBUG_INFO -c -fmessage-length=0 -I../../fsbl35_bsp/ps7_cortexa9_0/include -MMD -MP -MF"src/ddr_init.d" -MT"src/ddr_init.d" -o "src/ddr_init.o" "../src/ddr_init.c"
arm-xilinx-eabi-gcc: error: FSBL_DEBUG_INFO: No such file or directory
make: *** [src/ddr_init.o] Error 1
@sampatd
I have put -D in flag as -DFSBL_DEBUG and now it is showing no error.
I am able to run it on board but when i am booting from flash some unreonised messages are coming as:
[Wed May 14 20:26:13.361 2014]  ð°ÑÜÑÞð@Ñâãì@£ìÁÏÍ@ßßì@ßÁÌÍâ@¢ÍÜÍÁãÍ@al^m_b`ac^aÁñ@al@b`al]b`r`orcp£ÑÜÑÃßÞ@®ÍâãÑßÞ@a^`ßßì@ÝßÌÍ@Ñã@¡£ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^£­££­¿
[Wed May
 14 20:26:14.105 2014] £@£ìÁìíã@}@`ða ¢¬¿¢¬¿
Wed May 14 20:26:19.499 2014] ¢@£@£ìÁìíã@}@`ðc`c ¢¬¿¢¬¿
Wed May 14 20:26:19.551 2014] ¢@£@£ìÁìíã@}@`ðc`c ¢¬¿¢¬¿
[Wed May 14 20:26:19.551 2014] ¢@£@£ìÁìíã@}@`ðc`c ¢¬¿¢¬¿
Wed May 14 20:26:19.602 2014] ¢@£@£ìÁìíã@}@`ðc`c ¢¬¿¢¬¿
Wed May 14 20:26:19.602 2014] ¢@£@£ìÁìíã@@`ðc`c ¢¬¿¢¬¿
@sampatd
I am trying this now on another PC and microzed board.
Just to clarify: after setting compilation flags for debug,  do I need to uncomment xil_printf statements (that are commented by default) in ps7_init.c files, to see the log messages ? do I need to do this in orher files also?
If so then the role of FSBL_DEBUG and FSBL_DEBUG_INFO is governed by me , what I comment of uncomment in ps7_init files. Something is wrong in my understanding.  Please enlighten me.
Scholar sampatd
You do not need additional print statements in the FSBL code (unless you want them for specific reason). Your setting should be as shown:
If you take a look at the FSBL source code, the debug prints are already present:
