dongtrungthao
Problem about download and cable , help me
AutoDetecting cable. Please wait.
Connecting to cable (USB Port).
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
Driver windrvr6.sys version = 6.2.2.2. LPT base address = 0378h.
ECP base address = 0778h.
Connecting to cable (Parallel Port - LPT2).
Driver windrvr6.sys version = 6.2.2.2.Cable connection failed.
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
File D:\WINDOWS\system32\drivers\xusbdfwu.sys not found.
Inf File = D:\WINDOWS\inf\oem3.inf.
Found version. DriverVer=12/29/2004, 1.0.1.7
version = 1.0.1.7.
inf version = 1017(decimal).
Driver file not found. Inf file version = 0.
Driver xusbdfwu.sys version: 1017 (1017).
Connecting to cable (COM1 Port).
Done.
Help me , plz show me what happen??? Program error ??, or cable error ???, before i use it very good . But today this problem appear , I use cable Parallel IV with kit ML300 .
cciressan
You have a problem with the cable drivers.
There are two : windrvr6.sys and xpc4drvr.sys.
The first is there and is version 6.2.2.2 (you probably have version 7.1 of the tools) ...
The second should be in C:\WINDOWS\system32\drivers ....
There may be several causes for this problem:
1) either you installed a second ISE tool (e.g 7.1 and 9.2) during a upgrade/downgrade and corrupted the cable drivers.
2) or installed meanwhile some other hw/sw on your system that is using windrvr6.sys ..
3) ???
Anyway, you should be able to use the cable IV in compatibility mode.
For this go to "Output->Cable Setup" in Impact and check Parallel III on your LPT (probably 1).
This is also called compatibility mode and does not need the drivers :)))
This way you can check if your cable is still alive and solve your problem step-by-step.
Good luck,
CRC
