Problem compiling code on EDK 11.4
  I got a new machine which has windows xp 32bit on it. Installed Xilinx ISE 11.4. When I try to compile my design in EDK it stops at one point and doesnt move forward (doesnt compile fully). It doesnt even show any error and the little blue wheel on the lower right corner keeps on rotating. Also, I compiled the same code on my old computer. It compiled successfully.
Last few lines in the console where it got struck:
Running Xilinx Implementation tools..
xflow -wd implementation -p xc5vfx70tff1136-1 -implement xflow.opt -ise ../__xps/ise/system.ise system.ngc
Release 11.4 - Xflow L.68 (nt)
Copyright (c) 1995-2009 Xilinx, Inc.  All rights reserved.
xflow.exe -wd implementation -p xc5vfx70tff1136-1 -implement xflow.opt -ise
PMSPEC -- Overriding Xilinx file <C:/Xilinx/11.1/EDK/virtex5/data/virtex5.acd>
with local file <c:/Xilinx/11.1/ISE/virtex5/data/virtex5.acd>
.... Copying flowfile c:/Xilinx/11.1/ISE/xilinx/data/fpga.flw into working
directory
C:/Development/IMS_TOF/IMSTOF_DataACQ_V2_NoChipscope_long7_mry_monitor_1_1024/im
plementation
Using Flow File:
plementation/fpga.flw
Using Option File(s):
mplementation/xflow.opt
Dont know what to do. Please let me know if any one has any suggestion.
Bhuvan
Re: Problem compiling code on EDK 11.4
Finally, found solution for this problem.
http://www.xilinx.com/support/answers/35351.htm
Bhuvan
Bhuvan
