Problem: error `__gxx_personality_sj0' in c++ with classes
I'm trying to get a very simple test program working in c++ on a Spartan 3E starter board.
I want to use classes so I have to use c++.
The following code works:
#include <stdio.h>
class Car
private:
int nb;
public:
Car(int number)
nb = number;
~Car() {};
int GetNumber()
return nb;
int main()
int val = 0;
xil_printf("testing %d\n",123);
Car bmw(val);
val = bmw.GetNumber();
//xil_printf("testing %d\n",val);
return 0;
But when I discomment   ' //xil_printf("testing %d\n",val); '
I get the error:
main.o: In function `main':
/cygdrive/c/Xilinx/Now_Testing/TestSDK/SDK_projects/testOSplus/Debug/../main.cpp:26: undefined reference to `__gxx_personality_sj0'
I can't solve the problem, and I don't have that much knowledge about C compilers (gcc, g++, ...), libraries, ....
Can someone help me? if you need more information, just ask.
Message Edited by jmaes on 11-08-2009 09:58 AM
I've solved it!
I read somewherefor AVR microcontroller:
  • The operators new and delete are not implemented, attempting to use them will cause the linker to complain about undefined external references. (This could perhaps be fixed.)
  • Some of the supplied include files are not C++ safe, i. e. they need to be wrapped into
     extern "C" { . . . }
    (This could certainly be fixed, too.)
  • Exceptions are not supported. Since exceptions are enabled by default in the C++ frontend, they explicitly need to be turned off using -fno-exceptions in the compiler options. Failing this, the linker will complain about an undefined external reference to __gxx_personality_sj0.
So the first thing I did, was deleting the destructor (to avoid any reference to a delete command). And it worked!
Thanks anyway :)
This issue can be overcome by changing the file extension from '.C' (uppercase) to '.c'(lower case).
Hmm, I'm not so sure I understand....
Because I want classes, I'm using c++. So the name of my main file is "main.cpp", with cpp in small letters.
So I can't solve the problem that way, unless you were referring to something else?
(extra: I had the same problem in standalone v2.0, als in xilkernel 4.0)
Thanks for responding
I've solved it!
Thanks anyway :)
