meta1360
Problem in generating BSP in SDK
Hi all,
I am using Vivado 2015.2  I export my design to SDK and lunch it then I want to make a new project but when I fill the application project windows and push next and choose an empty application or hello word I go this error
please look at the picture attached here
Please help me out of this problem I downgraded my software to 2014.4 but I got the same problem and it is very frustrating and I really appreciate all your help in advance . I also attached the log file in cases it is needded.
Meysam
12:00:24 ERROR : Internal error: Num intr inputs 2 not the same as length of ::hsi::utils::get_interrupt_sources 1 hsi_error
can't read "source_name(1)": no such element in array
[Hsi 55-1545] Problem running tcl command ::sw_intc_v3_3::generate : can't read "source_name(1)": no such element in array
while executing
"string compare -nocase $source_name($i) "system""
("foreach" body line 34)
invoked from within
"foreach periph $periphs {
# Get the edk based name of peripheral for printing redefines
set periph_ip_name [common::get_property NAME..."
(procedure "xredefine_intc" line 10)
invoked from within
"xredefine_intc $drv_handle $file_handle"
(procedure "xdefine_canonical_xpars" line 71)
invoked from within
"xdefine_canonical_xpars $drv_handle "xparameters.h" "Intc" "DEVICE_ID" "C_BASEADDR" "C_HIGHADDR" "C_KIND_OF_INTR" "C_HAS_FAST" "C_IVAR_RESET_VALUE" "C..."
(procedure "::sw_intc_v3_3::generate" line 57)
invoked from within
"::sw_intc_v3_3::generate microblaze_0_axi_intc"
[Hsi 55-1442] Error(s) while running TCL procedure generate()
12:00:24 ERROR : Error generating bsp sources: Failed to generate BSP.
achutha
@meta1360
The issue is with your block design interrupt connection.In which you have not connected the other pin of concat IP as you only have 1 interrupt.
Double clicking on concat IP and set the width to 1 will resolve the issue.After the changing the settings and validating the design you should see similar to modified snippet.
Modified snippet:
Hope this helps.
-Achutha
achutha
Can you try using the zynq pre-defined hardware inSDK to understand if this is your exported HW issue or anything else?
Please share the block design or hdf to replicate the issue.
-Achutha
meta1360
Thanks Achutha for your reply.
Yes this issue is because of my design because as you said when I try it with pre-defined design it works and I can have a new project.
I attached my blobk design (bd file) and hdf file here
should you need more information please let me know.
thanks for spending time on this
Meysam
sampatd
I got the same error in SDK 2015.2 using the hdf you attached. I could not check the block the design as you might have some custom IPs.
Can you post a screenshot of your block diagram?
Do you receive any critical warnings when generating the bitstream in Vivado?
meta1360
thank you so much for your reply
I attached the photo of my design, yes I have a customized IP called BTM if it is helpful I can attach that IP as well.
in that step no there is not any critical warning but in implementation, I got some which are about set_property for some inputs and outputs which do not exist anymore and I think it is not a big deal.
I really appreciate all your help.
Meysam
sampatd
If possible can you archive the Vivado Project and attach it here?  I can take a look.
Otherwise, I can send you an FTP link where you can attach the archived project securely.
achutha
@meta1360
The issue you are seeing seems to be similar to the issue discussed in the answer record http://www.xilinx.com/support/answers/60969.html
It looks like you have custom IP in your design and so i was not able to review the block design using the BD shared.
As suggested by Sampat please archive the Vivado project and share it with us.
-Achutha
meta1360
I could not attache here please find it in
http://speedy.sh/TWhSG/MB-BTM-Multiple-RANK.zip
thanks for your help.
achutha
@meta1360
Modified snippet:
Hope this helps.
-Achutha
meta1360
thanks for your help, it works.
