Visitor ruizmartinez
Problem in using Modelsim SE 6.5c with EDK 11.1
i have this problem with the Simulation libraries compilation
____ ____
/___/ \ / VENDOR : Xilinx Inc.
\ \ \/ VERSION : 11.1 (L.33)
\ \ APPLICATION : C:\Xilinx\11.1\ISE\bin\nt\unwrapped\compxlib.exe
/ / CONTENTS : Compilation Log
/___/ /\ FILENAME : compxlib.log
\___\/\___\
Release 11.1 - C:\Xilinx\11.1\ISE\bin\nt\unwrapped\compxlib.exe L.33 (nt)
Copyright (c) 1995-2009 Xilinx, Inc. All rights reserved.
Processing command line ...
Reading the compxlib configuration file - 'compxlib.cfg' ...
Library Source Paths => 'C:/Xilinx/11.1/ISE'
Current Working Directory => 'C:\Documents and Settings\ruizmartinez\My Documents\RuizMartinez\ISE projects\Prueba1'
Compilation Mode = FAST
Execute Mode = ON
Scheduling library installation & compilation for architectures: virtex5
Scheduling library installation & compilation for libraries: simprim unisim xilinxcorelib edk
Signature:-
C:\Xilinx\11.1\ISE\bin\nt\unwrapped\compxlib.exe -s mti_se -l vhdl -p C:/ModelSimSE65/win32 -arch virtex5 -lib unisim -lib simprim -lib xilinxcorelib -lib edk -exclude_deprecated -intstyle ise
Setting up the simulator 'mti_se' for compilation ...
Setting up the source libraries for simulator 'mti_se' ...
Retrieving the .pao files for EDK library ...
Building the library hierarchies from the .pao files for EDK library ...
Assigning the netlist files to the hierarchies for EDK library ...
Compiling Xilinx HDL Libraries for 'mti_se' simulator
Model Technology ModelSim SE vcom 6.5 Compiler 2009.01 Jan 22 2009
Language => 'vhdl,verilog'
Output directory => 'C:\Xilinx\11.1\ISE'
Library verilog.secureip will not be compiled, because precompiled info is up to date.
compxlib[verilog.secureip]: 0 error(s), 0 warning(s), 12.50 % complete
Library vhdl.unisim will be compiled, because precompiled info is outdated.
--> Compiling vhdl.unisim library ...
> vhdl.unisim library compiled from C:/Xilinx/11.1/ISE/vhdl/src/unisims
> vhdl.unisim library compiled to C:\Xilinx\11.1\ISE\vhdl\mti_se/unisim
Modifying modelsim.ini
p, li { white-space: pre-wrap; }
> Log file 'C:\Xilinx\11.1\ISE\vhdl\mti_se/unisim/.cxl.vhdl.unisim.unisim.nt.log' generated
Library vhdl.unisim:vhdl.unimacro will be compiled, because precompiled info is outdated.
--> Compiling vhdl.unisim:vhdl.unimacro library ...
> vhdl.unisim:vhdl.unimacro library compiled from C:/Xilinx/11.1/ISE/vhdl/src/unimacro
> vhdl.unisim:vhdl.unimacro library compiled to C:\Xilinx\11.1\ISE\vhdl\mti_se/unimacro
-- Loading package standard
-- Loading package std_logic_1164
-- Loading package numeric_std
-- Loading package std_logic_arith
-- Loading package std_logic_unsigned
-- Loading package vcomponents
-- Loading package textio
-- Compiling entity addmacc_macro
-- Compiling architecture addmacc of addmacc_macro
###### C:/Xilinx/11.1/ISE/vhdl/src/unimacro/ADDMACC_MACRO.vhd(296): DSP48E_1: DSP48E1
** Error: C:/Xilinx/11.1/ISE/vhdl/src/unimacro/ADDMACC_MACRO.vhd(296): (vcom-1141) Identifier "dsp48e1" does not identify a component declaration.
###### C:/Xilinx/11.1/ISE/vhdl/src/unimacro/ADDMACC_MACRO.vhd(361): DSP48E_2: DSP48A1
** Error: C:/Xilinx/11.1/ISE/vhdl/src/unimacro/ADDMACC_MACRO.vhd(361): (vcom-1141) Identifier "dsp48a1" does not identify a component declaration.
###### C:/Xilinx/11.1/ISE/vhdl/src/unimacro/ADDMACC_MACRO.vhd(405): end addmacc;
** Error: C:/Xilinx/11.1/ISE/vhdl/src/unimacro/ADDMACC_MACRO.vhd(405): VHDL Compiler exiting
I don't know if the spaces in the directory is the problem ....
Thank you very much in advance for your help ...
Emilio
Re: Problem in using Modelsim SE 6.5c with EDK 11.1
I still think you have the working directory on the Desktop, so it is having spaces in the project location.
Please keep the output directory of the compiled libraries in another location without any spaces.
thanks for your answer, but it is still not working..... i've changed the current working directory to
Current Working Directory => 'C:\pp\lolo'
 and the output directory is >>>
I still have the same error
> Log file 'C:\Xilinx\11.1\ISE\vhdl\mti_se/unimacro/.cxl.vhdl.unimacro.unimacro.nt.log' generated
compxlib[vhdl.unisim:vhdl.unimacro]: 1 error(s), 0 warning(s)
INFO:Compxlib:370 - Please refer to the compile log file 'C:\Xilinx\11.1\ISE\vhdl\mti_se/unimacro/.cxl.vhdl.unimacro.unimacro.nt.log' for details of compilation error(s).
Library vhdl.unisim:vhdl.secureip_vhdl_unisim will not be compiled, because precompiled info is up to date.
compxlib[vhdl.unisim:vhdl.secureip_vhdl_unisim]: 0 error(s), 0 warning(s)
compxlib[vhdl.unisim]: 1 error(s), 0 warning(s), 25.00 % complete
thank you very much for your help....
