Problem integrating EDK project in ISE 10.1
I just installed the latest service packs for EDK and ISE and trying to combine my EDK top level and my VHDL codes in ISE. But no matter what I do, I get the following error message:
Xilinx Platform Studio
Xilinx EDK 10.1.03 Build EDK_K_SP3.6
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
ERROR:MDT - Error while performing Cygwin checks....
ERROR: The Device Settings in the ISE project do not match those in
 the XPS project. You will need to change them so that they
 match in order to use the XPS design with ISE.
 I have looked at:
http://www.xilinx.com/support/answers/30456.htm
http://www.xilinx.com/support/answers/30846.htm
And even re-installed my ISE but nothing seems to work.
Does anyone know how I can solve this?
Individually both tools work without any problems, but it seems like my ISE does not like the EXACT same device used on EDK.
Really appreciate your help,
Best regards,
/Farhad
PS. I am on Windows XP
Tags (5)
Solved the problem myself by installing the latest Cygwin to my PC and copied it over the old Cygwin under EDK.
After that, I re-generated all the libraries and re-created all the applications, that solve the problem.
This is really unprofressional of Xilinx not to include the correct Cygwin with the latest EDK installation.
BR,
/Farhad
Ok,
I re-installed  both the ISE and EDK and updated them to SP3. Now the connection between the 2 tools work fine,but I can no longer generate simulation files to simulate my design.
Copying files for driver cpu_v1_11_b from
C:\Xilinx\10.1\EDK\sw\XilinxProcessorIPLib\drivers\cpu_v1_11_b\src\ to
<name removed>\FPGA\edk\microblaze_0\libsrc\cpu_v1_11_b\ ...
/usr/bin/bash: igncr: unknown option name
ERROR:MDT - Error while running "Copy Files" for processor microblaze_0...
make: *** [microblaze_0/lib/libxil.a] Error 2
Done!
Does this mean that the cygwin included in EDK is not fully compatible with the EDK?
TIA,
/Farhad
BR,
/Farhad
Historian
Historian
The latest Cygwin is a moving target.  By the time the Xilinx tools ship, Cygwin has moved on.
The real problem is that newer versions of Cygwin might not be completely compatible with earlier versions.
-a
I don't agree with you here. It is not that Cygwin is installed seperately, but it is the one sent by Xilinx even after the installation of the SP3 that does not work, I would have been more than happy to remove Cygwin from my system (as I did) and only install Xilinx ISE and EDK, but the problem was that the Cygwin version delivered wuth EDK didn't work for me.
