tejna
Problem with IP Integrator and SDK
I am fairly new to developing projects using FPGAs especially using Vivado tools. I am working on developing a graphics application on Arty S7 development board which has the Spartan7 FPGA. When I create the project just using VHDL, I am able to see the graphics output on screen. But when I create an IP core for the project and add Microblaze to it using IP Integrator, and export the hardware to SDK to program it, I am not able to see the right output on screen. I can just see a black screen, so not sure where I am going wrong. I was wondering if it has anything to do with clocking or timing. Again I am really sorry if the question seems basic, but do we have to add separate timing constraints file for the project? Because when I did the same project using Xilinx ISE, there was no need for manual timing constraints.
Thank you so much in advance for your time and help.
Tejna
ritakur
Did you generate the bitstream before the exported the HW to SDK?  if you are using Xilinx reference board and the I/Os on board, you don't need to modify the timing constraints.
Please refer to the embedded tutorial Lab 3 to create a MicroBlaze system design. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug940-vivado-tutorial-embedded-design.pdf
