Scholar dpaul24
Problem with Linken script generation (Viv + SDK 2015.4) for MicroBlaze 9.5
I have successfully implemented and exported to SDK a Microblaze design having 256MB BRAM as instruction memory (via ILMB) and UARTLite other than clocks and resets.
However when I am trying to create hello world C code, I am getting a "Error generating Linker script" message. Below I have copied the messages from the SDK Log window.
17:08:19 INFO	: Launching XSDB server: xsdb.bat C:/Xilinx/SDK/2015.4/scripts/xsdb/xsdb/xsdb-server.tcl
17:08:20 INFO	: XSDB server has started successfully.
17:08:20 INFO	: Processing command line option -hwspec D:/work/Xilinx/uB_sys_design/uB_bd/uB_sys.sdk/uB_bd_wrapper.hdf.
17:11:45 ERROR	: (XSDB Server)ERROR: [Hsi 55-1573] The hardware system does not have a memory that can locate program data Section
ERROR: [Hsi 55-1422] Cannot initialize LinkGen Engine.
ERROR: [Hsi 55-1435] Error generating linker script
17:11:45 ERROR	: (XSDB Server)ERROR: [Hsi 55-1438] Error running generate_app.
17:11:45 ERROR	: Failed to call GENERATE_APP
Reason: ERROR: [Common 17-39] 'hsi::generate_app' failed due to earlier errors.
17:11:45 ERROR	:
java.lang.RuntimeException: Failed to call GENERATE_APP
The GUI Error window is also attached.
Could it be that the BMM file for the uBlaze was not properly imported?
Please direct me to solutions and/or suggestions in order to resolve the error.
FPGA enthusiast!
All PMs will be ignored
Scholar stephenm
Re: Problem with Linken script generation (Viv + SDK 2015.4) for MicroBlaze 9.5
Can you post a screenshot of your BD (Block design) of your memory structure. it sounds like you havent connected your DLMB memory on the Microblaze?
Scholar stephenm
Scholar dpaul24
Hi Stephenm,
Yes, I have left the DLMB unconnected.
Ah....now I see, the following message points to it! I think I can fix it.
I should have read the error message more carefully! But it was Friday evening when I posted this message so...............
FPGA enthusiast!
