samboy786
Problem with PCI implementation on ML510 board
I am trying to injterface a PCI (5V) card with  ML510 board using PPC440@125MHz. I am stuck with the interrrupt controller core. I am using ISE 13.2 design suite. When I am importing the mhs file to SDK, it fails to generate the corresponding libraries files for interrupt controller ( xps_intc) giving the following error message :
Staging source files.
Running DRCs.
MFS DRC ...
Running generate.
ERROR:EDK - intc () - Internal error: Number of interrupt inputs on xps_intc_0
(2) is not the same as length of total number of interrupt sources (6). If
any interrupt source is a vector then libgen does not support this use case
MFS generate ...
ERROR:EDK:3416 - Error(s) while running TCL procedure generate().
I have tried c
hecking number of interrupt inputs on intc . It is 6 in mhs file while the mpd shows only two. I have also tried changing the C_NUM_INTR_INPUTS in the original mpd file from 2 to 6. I have changed these parameters in the hdl files ( intc_core and xps_intc) as well. But nothing seems to produce any change in the output. I am getting the same error all over the time.
I am attaching the MHS file for reference. Plz help asap :( :(
PARAMETER VERSION = 2.1.0
PORT fpga_0_RS232_Uart_1_RX_pin = fpga_0_RS232_Uart_1_RX_pin, DIR = I
PORT fpga_0_RS232_Uart_1_TX_pin = fpga_0_RS232_Uart_1_TX_pin, DIR = O
PORT fpga_0_LEDs_4Bit_GPIO_IO_pin = fpga_0_LEDs_4Bit_GPIO_IO_pin, DIR = IO, VEC = [0:3]
PORT fpga_0_FLASH_Mem_A_pin = fpga_0_FLASH_Mem_A_pin_vslice_7_30_concat, DIR = O, VEC = [7:30]
PORT fpga_0_FLASH_Mem_CEN_pin = fpga_0_FLASH_Mem_CEN_pin, DIR = O
PORT fpga_0_FLASH_Mem_OEN_pin = fpga_0_FLASH_Mem_OEN_pin, DIR = O
PORT fpga_0_FLASH_Mem_WEN_pin = fpga_0_FLASH_Mem_WEN_pin, DIR = O
PORT fpga_0_FLASH_Mem_ADV_LDN_pin = fpga_0_FLASH_Mem_ADV_LDN_pin, DIR = O
PORT fpga_0_FLASH_Mem_DQ_pin = fpga_0_FLASH_Mem_DQ_pin, DIR = IO, VEC = [0:15]
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_Clk_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_Clk_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_Clk_n_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_Clk_n_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_CE_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_CE_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_CS_n_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_CS_n_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_ODT_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_ODT_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_RAS_n_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_RAS_n_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_CAS_n_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_CAS_n_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_WE_n_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_WE_n_pin, DIR = O
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_BankAddr_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_BankAddr_pin, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_Addr_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_Addr_pin, DIR = O, VEC = [13:0]
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQ_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQ_pin, DIR = IO, VEC = [63:0]
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_DM_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DM_pin, DIR = O, VEC = [7:0]
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQS_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQS_pin, DIR = IO, VEC = [7:0]
PORT fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQS_n_pin = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQS_n_pin, DIR = IO, VEC = [7:0]
PORT fpga_0_pci_arbiter_0_PCI_Req_n_pin = fpga_0_pci_arbiter_0_PCI_Req_n_pin_vslice_1_5_concat, DIR = I, VEC = [1:5]
PORT fpga_0_pci_arbiter_0_PCI_Gnt_n_pin = fpga_0_pci_arbiter_0_PCI_Gnt_n_pin_vslice_1_5_concat, DIR = O, VEC = [1:5]
PORT fpga_0_PCI32_BRIDGE_AD_pin = fpga_0_PCI32_BRIDGE_AD_pin, DIR = IO, VEC = [31:0]
PORT fpga_0_PCI32_BRIDGE_CBE_pin = fpga_0_PCI32_BRIDGE_CBE_pin, DIR = IO, VEC = [3:0]
PORT fpga_0_PCI32_BRIDGE_PAR_pin = fpga_0_PCI32_BRIDGE_PAR_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_FRAME_N_pin = fpga_0_PCI32_BRIDGE_FRAME_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_TRDY_N_pin = fpga_0_PCI32_BRIDGE_TRDY_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_IRDY_N_pin = fpga_0_PCI32_BRIDGE_IRDY_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_STOP_N_pin = fpga_0_PCI32_BRIDGE_STOP_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_DEVSEL_N_pin = fpga_0_PCI32_BRIDGE_DEVSEL_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_PERR_N_pin = fpga_0_PCI32_BRIDGE_PERR_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_SERR_N_pin = fpga_0_PCI32_BRIDGE_SERR_N_pin, DIR = IO
PORT fpga_0_PCI32_BRIDGE_PCI_INTA_pin = fpga_0_PCI32_BRIDGE_PCI_INTA_pin, DIR = I, SIGIS = INTERRUPT, SENSITIVITY = LEVEL_LOW, INTERRUPT_PRIORITY = MEDIUM
PORT fpga_0_PCI32_BRIDGE_PCI_INTB_pin = fpga_0_PCI32_BRIDGE_PCI_INTB_pin, DIR = I, SIGIS = INTERRUPT, SENSITIVITY = LEVEL_LOW, INTERRUPT_PRIORITY = MEDIUM
PORT fpga_0_PCI32_BRIDGE_PCI_INTC_pin = fpga_0_PCI32_BRIDGE_PCI_INTC_pin, DIR = I, SIGIS = INTERRUPT, SENSITIVITY = LEVEL_LOW, INTERRUPT_PRIORITY = MEDIUM
PORT fpga_0_PCI32_BRIDGE_PCI_INTD_pin = fpga_0_PCI32_BRIDGE_PCI_INTD_pin, DIR = I, SIGIS = INTERRUPT, SENSITIVITY = LEVEL_LOW, INTERRUPT_PRIORITY = MEDIUM
PORT fpga_0_PCI32_BRIDGE_PCI_SBR_INT_pin = fpga_0_PCI32_BRIDGE_PCI_SBR_INT_pin, DIR = I, SIGIS = INTERRUPT, SENSITIVITY = LEVEL_HIGH, INTERRUPT_PRIORITY = MEDIUM
PORT fpga_0_PCI32_BRIDGE_PCI_CLK_OUT0_pin = clk_33_3333MHz, DIR = O
PORT fpga_0_PCI32_BRIDGE_PCI_CLK_OUT1_pin = clk_33_3333MHz, DIR = O
PORT fpga_0_PCI32_BRIDGE_PCI_CLK_OUT3_pin = clk_33_3333MHz, DIR = O
PORT fpga_0_PCI32_BRIDGE_PCI_CLK_OUT4_pin = clk_33_3333MHz, DIR = O
PORT fpga_0_PCI32_BRIDGE_PCI_CLK_OUT5_pin = clk_33_3333MHz, DIR = O
PORT fpga_0_PCI32_BRIDGE_PCI_CLK_FB_pin = pci_feedback_s, DIR = I, SIGIS = CLK, CLK_FREQ = 33333333
PORT fpga_0_SysACE_CompactFlash_SysACE_MPA_pin = fpga_0_SysACE_CompactFlash_SysACE_MPA_pin, DIR = O, VEC = [6:0]
PORT fpga_0_SysACE_CompactFlash_SysACE_CLK_pin = fpga_0_SysACE_CompactFlash_SysACE_CLK_pin, DIR = I
PORT fpga_0_SysACE_CompactFlash_SysACE_MPIRQ_pin = fpga_0_SysACE_CompactFlash_SysACE_MPIRQ_pin, DIR = I
PORT fpga_0_SysACE_CompactFlash_SysACE_CEN_pin = fpga_0_SysACE_CompactFlash_SysACE_CEN_pin, DIR = O
PORT fpga_0_SysACE_CompactFlash_SysACE_OEN_pin = fpga_0_SysACE_CompactFlash_SysACE_OEN_pin, DIR = O
PORT fpga_0_SysACE_CompactFlash_SysACE_WEN_pin = fpga_0_SysACE_CompactFlash_SysACE_WEN_pin, DIR = O
PORT fpga_0_SysACE_CompactFlash_SysACE_MPD_pin = fpga_0_SysACE_CompactFlash_SysACE_MPD_pin, DIR = IO, VEC = [15:0]
PORT fpga_0_clk_1_sys_clk_pin = CLK_S, DIR = I, SIGIS = CLK, CLK_FREQ = 100000000
PORT fpga_0_rst_1_sys_rst_pin = sys_rst_s, DIR = I, SIGIS = RST, RST_POLARITY = 0
PORT fpga_0_ORGate_1_Res_SBR_PWG_RSM_RSTJ_pin = fpga_0_ORGate_1_Res_pin, DIR = O
PORT fpga_0_ORGate_1_Res_PCI_reset_all_pin = fpga_0_ORGate_1_Res_pin, DIR = O
BEGIN ppc440_virtex5
PARAMETER INSTANCE = ppc440_0
PARAMETER C_IDCR_BASEADDR = 0b0000000000
PARAMETER C_IDCR_HIGHADDR = 0b0011111111
PARAMETER C_SPLB0_USE_MPLB_ADDR = 1
PARAMETER C_SPLB0_NUM_MPLB_ADDR_RNG = 2
PARAMETER C_SPLB1_NUM_MPLB_ADDR_RNG = 0
PARAMETER HW_VER = 1.01.a
PARAMETER C_SPLB0_RNG0_MPLB_BASEADDR = 0x00000000
PARAMETER C_SPLB0_RNG0_MPLB_HIGHADDR = 0x1fffffff
PARAMETER C_SPLB0_RNG1_MPLB_BASEADDR = 0x80000000
PARAMETER C_SPLB0_RNG1_MPLB_HIGHADDR = 0xffffffff
BUS_INTERFACE MPLB = plb_v46_0
BUS_INTERFACE SPLB0 = ppc440_0_SPLB0
BUS_INTERFACE JTAGPPC = ppc440_0_jtagppc_bus
BUS_INTERFACE RESETPPC = ppc_reset_bus
PORT CPMC440CLK = clk_125_0000MHzPLL0
PORT CPMINTERCONNECTCLK = clk_125_0000MHzPLL0
PORT CPMINTERCONNECTCLKNTO1 = net_vcc
PORT EICC440EXTIRQ = ppc440_0_EICC440EXTIRQ
PORT CPMMCCLK = clk_125_0000MHzPLL0_ADJUST
END
BEGIN plb_v46
PARAMETER INSTANCE = plb_v46_0
PARAMETER C_DCR_INTFCE = 0
PARAMETER HW_VER = 1.05.a
PORT PLB_Clk = clk_125_0000MHzPLL0_ADJUST
PORT SYS_Rst = sys_bus_reset
END
BEGIN xps_bram_if_cntlr
PARAMETER INSTANCE = xps_bram_if_cntlr_1
PARAMETER C_SPLB_NATIVE_DWIDTH = 64
PARAMETER C_SPLB_SUPPORT_BURSTS = 1
PARAMETER C_SPLB_P2P = 0
PARAMETER HW_VER = 1.00.b
PARAMETER C_BASEADDR = 0xffff8000
PARAMETER C_HIGHADDR = 0xffffffff
BUS_INTERFACE SPLB = plb_v46_0
BUS_INTERFACE PORTA = xps_bram_if_cntlr_1_port
END
BEGIN bram_block
PARAMETER INSTANCE = xps_bram_if_cntlr_1_bram
PARAMETER HW_VER = 1.00.a
END
BEGIN xps_uartlite
PARAMETER INSTANCE = RS232_Uart_1
PARAMETER C_BAUDRATE = 9600
PARAMETER C_DATA_BITS = 8
PARAMETER C_USE_PARITY = 0
PARAMETER C_ODD_PARITY = 0
PARAMETER HW_VER = 1.02.a
PARAMETER C_BASEADDR = 0x84000000
PARAMETER C_HIGHADDR = 0x8400ffff
PORT RX = fpga_0_RS232_Uart_1_RX_pin
PORT TX = fpga_0_RS232_Uart_1_TX_pin
END
BEGIN xps_gpio
PARAMETER INSTANCE = LEDs_4Bit
PARAMETER C_ALL_INPUTS = 0
PARAMETER C_GPIO_WIDTH = 4
PARAMETER C_INTERRUPT_PRESENT = 0
PARAMETER C_IS_DUAL = 0
PARAMETER HW_VER = 2.00.a
PARAMETER C_BASEADDR = 0x81400000
PARAMETER C_HIGHADDR = 0x8140ffff
PORT GPIO_IO = fpga_0_LEDs_4Bit_GPIO_IO_pin
END
BEGIN xps_mch_emc
PARAMETER INSTANCE = FLASH
PARAMETER C_NUM_BANKS_MEM = 1
PARAMETER C_NUM_CHANNELS = 0
PARAMETER C_MEM0_WIDTH = 16
PARAMETER C_MAX_MEM_WIDTH = 16
PARAMETER C_INCLUDE_DATAWIDTH_MATCHING_0 = 1
PARAMETER C_SYNCH_MEM_0 = 0
PARAMETER C_TCEDV_PS_MEM_0 = 110000
PARAMETER C_TAVDV_PS_MEM_0 = 110000
PARAMETER C_THZCE_PS_MEM_0 = 35000
PARAMETER C_TWC_PS_MEM_0 = 110000
PARAMETER C_TWP_PS_MEM_0 = 70000
PARAMETER C_TLZWE_PS_MEM_0 = 35000
PARAMETER HW_VER = 3.01.a
PARAMETER C_MEM0_BASEADDR = 0xe8000000
PARAMETER C_MEM0_HIGHADDR = 0xe9ffffff
PORT RdClk = clk_125_0000MHzPLL0_ADJUST
PORT Mem_A = 0b0000000 & fpga_0_FLASH_Mem_A_pin_vslice_7_30_concat & 0b0
PORT Mem_CEN = fpga_0_FLASH_Mem_CEN_pin
PORT Mem_OEN = fpga_0_FLASH_Mem_OEN_pin
PORT Mem_WEN = fpga_0_FLASH_Mem_WEN_pin
PORT Mem_ADV_LDN = fpga_0_FLASH_Mem_ADV_LDN_pin
PORT Mem_DQ = fpga_0_FLASH_Mem_DQ_pin
END
BEGIN mpmc
PARAMETER INSTANCE = DDR2_SDRAM_DIMM1
PARAMETER C_NUM_PORTS = 1
PARAMETER C_NUM_IDELAYCTRL = 3
PARAMETER C_IDELAYCTRL_LOC = IDELAYCTRL_X0Y2-IDELAYCTRL_X0Y3-IDELAYCTRL_X0Y4
PARAMETER C_MEM_PARTNO = WD2RE512X809-667D
PARAMETER C_MEM_ODT_TYPE = 1
PARAMETER C_MEM_CLK_WIDTH = 1
PARAMETER C_MEM_ODT_WIDTH = 1
PARAMETER C_MEM_CE_WIDTH = 1
PARAMETER C_MEM_CS_N_WIDTH = 1
PARAMETER C_MEM_DATA_WIDTH = 64
PARAMETER C_DDR2_DQSN_ENABLE = 1
PARAMETER C_PIM0_BASETYPE = 2
PARAMETER HW_VER = 6.04.a
PARAMETER C_MPMC_BASEADDR = 0x00000000
PARAMETER C_MPMC_HIGHADDR = 0x1fffffff
BUS_INTERFACE SPLB0 = plb_v46_0
PORT MPMC_Clk0 = clk_125_0000MHzPLL0_ADJUST
PORT MPMC_Clk0_DIV2 = clk_62_5000MHzPLL0_ADJUST
PORT MPMC_Clk90 = clk_125_0000MHz90PLL0_ADJUST
PORT MPMC_Clk_200MHz = clk_200_0000MHz
PORT MPMC_Rst = sys_periph_reset
PORT DDR2_Clk = fpga_0_DDR2_SDRAM_DIMM1_DDR2_Clk_pin
PORT DDR2_Clk_n = fpga_0_DDR2_SDRAM_DIMM1_DDR2_Clk_n_pin
PORT DDR2_CE = fpga_0_DDR2_SDRAM_DIMM1_DDR2_CE_pin
PORT DDR2_CS_n = fpga_0_DDR2_SDRAM_DIMM1_DDR2_CS_n_pin
PORT DDR2_ODT = fpga_0_DDR2_SDRAM_DIMM1_DDR2_ODT_pin
PORT DDR2_RAS_n = fpga_0_DDR2_SDRAM_DIMM1_DDR2_RAS_n_pin
PORT DDR2_CAS_n = fpga_0_DDR2_SDRAM_DIMM1_DDR2_CAS_n_pin
PORT DDR2_WE_n = fpga_0_DDR2_SDRAM_DIMM1_DDR2_WE_n_pin
PORT DDR2_BankAddr = fpga_0_DDR2_SDRAM_DIMM1_DDR2_BankAddr_pin
PORT DDR2_Addr = fpga_0_DDR2_SDRAM_DIMM1_DDR2_Addr_pin
PORT DDR2_DQ = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQ_pin
PORT DDR2_DM = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DM_pin
PORT DDR2_DQS = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQS_pin
PORT DDR2_DQS_n = fpga_0_DDR2_SDRAM_DIMM1_DDR2_DQS_n_pin
END
BEGIN pci_arbiter
PARAMETER INSTANCE = pci_arbiter_0
PARAMETER C_NUM_PCI_MSTRS = 6
PORT PCI_Clk = pci_feedback_s
PORT PCI_Rst_n = net_vcc
PORT PCI_Req_n = fpga_0_pci_arbiter_0_PCI_Req_n_pin_vslice_0_0_concat & fpga_0_pci_arbiter_0_PCI_Req_n_pin_vslice_1_5_concat
PORT PCI_Gnt_n = fpga_0_pci_arbiter_0_PCI_Gnt_n_pin_vslice_0_0_concat & fpga_0_pci_arbiter_0_PCI_Gnt_n_pin_vslice_1_5_concat
PORT PCI_Frame_n = net_bsbassign0
PORT PCI_Irdy_n = net_bsbassign2
END
BEGIN plbv46_pci
PARAMETER INSTANCE = PCI32_BRIDGE
PARAMETER C_NUM_IDELAYCTRL = 2
PARAMETER C_IDELAYCTRL_LOC = IDELAYCTRL_X2Y7-IDELAYCTRL_X2Y8
PARAMETER C_INCLUDE_INTR_A_BUF = 0
PARAMETER C_INCLUDE_REQ_N_BUF = 0
PARAMETER C_TRIG_PCI_DATA_XFER_OCC_LEVEL = 16
PARAMETER C_IPIF2PCI_FIFO_ABUS_WIDTH = 9
PARAMETER C_PCI2IPIF_FIFO_ABUS_WIDTH = 9
PARAMETER C_NUM_PCI_RETRIES_IN_WRITES = 3000
PARAMETER C_NUM_PCI_PRDS_BETWN_RETRIES_IN_WRITES = 1
PARAMETER C_IPIFBAR_NUM = 2
PARAMETER C_IPIFBAR2PCIBAR_0 = 0x00000000
PARAMETER C_IPIF_SPACETYPE_0 = 1
PARAMETER C_IPIFBAR2PCIBAR_1 = 0x00000000
PARAMETER C_IPIF_SPACETYPE_1 = 0
PARAMETER C_PCIBAR_NUM = 1
PARAMETER C_PCIBAR2IPIFBAR_0 = 0x00000000
PARAMETER C_PCIBAR_LEN_0 = 29
PARAMETER C_DEVICE_ID = 0x0510
PARAMETER C_VENDOR_ID = 0x10EE
PARAMETER C_CLASS_CODE = 0x060000
PARAMETER C_REV_ID = 0x1A
PARAMETER C_SUBSYSTEM_ID = 0x0510
PARAMETER C_SUBSYSTEM_VENDOR_ID = 0x10EE
PARAMETER C_MAX_LAT = 0x54
PARAMETER C_MIN_GNT = 0x32
PARAMETER C_NUM_IDSEL = 16
PARAMETER C_BRIDGE_IDSEL_ADDR_BIT = 16
PARAMETER HW_VER = 1.04.a
PARAMETER C_BASEADDR = 0x85e00000
PARAMETER C_HIGHADDR = 0x85e0ffff
PARAMETER C_IPIFBAR_0 = 0xc0000000
PARAMETER C_IPIF_HIGHADDR_0 = 0xdfffffff
PARAMETER C_IPIFBAR_1 = 0xf0000000
PARAMETER C_IPIF_HIGHADDR_1 = 0xf3ffffff
BUS_INTERFACE MPLB = ppc440_0_SPLB0
PORT AD = fpga_0_PCI32_BRIDGE_AD_pin
PORT CBE = fpga_0_PCI32_BRIDGE_CBE_pin
PORT PAR = fpga_0_PCI32_BRIDGE_PAR_pin
PORT FRAME_N = fpga_0_PCI32_BRIDGE_FRAME_N_pin
PORT TRDY_N = fpga_0_PCI32_BRIDGE_TRDY_N_pin
PORT IRDY_N = fpga_0_PCI32_BRIDGE_IRDY_N_pin
PORT STOP_N = fpga_0_PCI32_BRIDGE_STOP_N_pin
PORT DEVSEL_N = fpga_0_PCI32_BRIDGE_DEVSEL_N_pin
PORT PERR_N = fpga_0_PCI32_BRIDGE_PERR_N_pin
PORT SERR_N = fpga_0_PCI32_BRIDGE_SERR_N_pin
PORT GNT_N = fpga_0_pci_arbiter_0_PCI_Gnt_n_pin_vslice_0_0_concat
PORT RST_N = net_vcc
PORT PCLK = pci_feedback_s
PORT RCLK = clk_200_0000MHz
PORT REQ_N_toArb = fpga_0_pci_arbiter_0_PCI_Req_n_pin_vslice_0_0_concat
PORT FRAME_I = net_bsbassign0
PORT IRDY_I = net_bsbassign2
PORT IP2INTC_Irpt = PCI32_BRIDGE_IP2INTC_Irpt
END
BEGIN plb_v46
PARAMETER INSTANCE = ppc440_0_SPLB0
END
BEGIN xps_sysace
PARAMETER INSTANCE = SysACE_CompactFlash
PARAMETER C_MEM_WIDTH = 16
PARAMETER C_BASEADDR = 0x83600000
PARAMETER C_HIGHADDR = 0x8360ffff
PORT SysACE_MPA = fpga_0_SysACE_CompactFlash_SysACE_MPA_pin
PORT SysACE_CLK = fpga_0_SysACE_CompactFlash_SysACE_CLK_pin
PORT SysACE_MPIRQ = fpga_0_SysACE_CompactFlash_SysACE_MPIRQ_pin
PORT SysACE_CEN = fpga_0_SysACE_CompactFlash_SysACE_CEN_pin
PORT SysACE_OEN = fpga_0_SysACE_CompactFlash_SysACE_OEN_pin
PORT SysACE_WEN = fpga_0_SysACE_CompactFlash_SysACE_WEN_pin
PORT SysACE_IRQ = SysACE_CompactFlash_SysACE_IRQ
PORT SysACE_MPD = fpga_0_SysACE_CompactFlash_SysACE_MPD_pin
END
BEGIN xps_timer
PARAMETER INSTANCE = xps_timer_0
PARAMETER C_COUNT_WIDTH = 32
PARAMETER C_ONE_TIMER_ONLY = 0
PARAMETER C_BASEADDR = 0x83c00000
PARAMETER C_HIGHADDR = 0x83c0ffff
PORT Interrupt = xps_timer_0_Interrupt
END
BEGIN util_reduced_logic
PARAMETER INSTANCE = ORGate_1
PARAMETER C_OPERATION = or
PARAMETER C_SIZE = 2
PORT Op1 = sys_rst_s & 0b0
PORT Res = fpga_0_ORGate_1_Res_pin
END
BEGIN clock_generator
PARAMETER INSTANCE = clock_generator_0
PARAMETER C_CLKIN_FREQ = 100000000
PARAMETER C_CLKOUT0_FREQ = 125000000
PARAMETER C_CLKOUT0_PHASE = 90
PARAMETER C_CLKOUT0_GROUP = PLL0_ADJUST
PARAMETER C_CLKOUT0_BUF = TRUE
PARAMETER C_CLKOUT1_FREQ = 125000000
PARAMETER C_CLKOUT1_PHASE = 0
PARAMETER C_CLKOUT1_GROUP = PLL0
PARAMETER C_CLKOUT1_BUF = TRUE
PARAMETER C_CLKOUT2_FREQ = 125000000
PARAMETER C_CLKOUT2_PHASE = 0
PARAMETER C_CLKOUT2_GROUP = PLL0_ADJUST
PARAMETER C_CLKOUT2_BUF = TRUE
PARAMETER C_CLKOUT3_FREQ = 200000000
PARAMETER C_CLKOUT3_PHASE = 0
PARAMETER C_CLKOUT3_GROUP = NONE
PARAMETER C_CLKOUT3_BUF = TRUE
PARAMETER C_CLKOUT4_FREQ = 33333333
PARAMETER C_CLKOUT4_PHASE = 0
PARAMETER C_CLKOUT4_GROUP = NONE
PARAMETER C_CLKOUT4_BUF = TRUE
PARAMETER C_CLKOUT5_FREQ = 62500000
PARAMETER C_CLKOUT5_PHASE = 0
PARAMETER C_CLKOUT5_GROUP = PLL0_ADJUST
PARAMETER C_CLKOUT5_BUF = TRUE
PARAMETER C_EXT_RESET_HIGH = 0
PARAMETER HW_VER = 4.02.a
PORT CLKIN = CLK_S
PORT CLKOUT0 = clk_125_0000MHz90PLL0_ADJUST
PORT CLKOUT1 = clk_125_0000MHzPLL0
PORT CLKOUT2 = clk_125_0000MHzPLL0_ADJUST
PORT CLKOUT3 = clk_200_0000MHz
PORT CLKOUT4 = clk_33_3333MHz
PORT CLKOUT5 = clk_62_5000MHzPLL0_ADJUST
PORT RST = sys_rst_s
PORT LOCKED = Dcm_all_locked
END
BEGIN jtagppc_cntlr
PARAMETER INSTANCE = jtagppc_cntlr_inst
PARAMETER HW_VER = 2.01.c
BUS_INTERFACE JTAGPPC0 = ppc440_0_jtagppc_bus
END
BEGIN proc_sys_reset
PARAMETER INSTANCE = proc_sys_reset_0
PARAMETER HW_VER = 3.00.a
BUS_INTERFACE RESETPPC0 = ppc_reset_bus
PORT Slowest_sync_clk = clk_125_0000MHzPLL0_ADJUST
PORT Ext_Reset_In = sys_rst_s
PORT Dcm_locked = Dcm_all_locked
PORT Bus_Struct_Reset = sys_bus_reset
PORT Peripheral_Reset = sys_periph_reset
END
BEGIN xps_intc
PARAMETER INSTANCE = xps_intc_0
PARAMETER HW_VER = 2.01.a
PARAMETER C_BASEADDR = 0x81800000
PARAMETER C_HIGHADDR = 0x8180ffff
PORT Intr = PCI32_BRIDGE_IP2INTC_Irpt & SysACE_CompactFlash_SysACE_IRQ & xps_timer_0_Interrupt & fpga_0_PCI32_BRIDGE_PCI_INTA_pin & fpga_0_PCI32_BRIDGE_PCI_INTB_pin & fpga_0_PCI32_BRIDGE_PCI_INTC_pin & fpga_0_PCI32_BRIDGE_PCI_INTD_pin & fpga_0_PCI32_BRIDGE_PCI_SBR_INT_pin
PORT Irq = ppc440_0_EICC440EXTIRQ
END
luisb
Have you tried creating a new project? It's possible the project is corrupt.
luisb
samboy786
I have tried it many a times ... i keep getting the same error-
MFS generate ...
htsvn
What is the OS that you are using? How does your MSS look like, i have tried to include MFS and was able to generate BSP for Standalone OS.
Thnx
samboy786
@hem_8030 and luisb
I think i have the answer now... :)
I have changed the workspace and its working well now...
Thanks for all the help
w8ryan
Good to know you fixed this... but what do you mean by changed the workspace? BTW - I have the same problem.
WBB
yinlinlijuan
Hello, I have the same problem,but I do not to solve it; Help!!!:smileysad:
