01-30-2009 07:11 AM
I am having a very strange problem. I can create add and remove projects and files into the XPS without any problem, but as soon as I choose the "Clean Project" on a SW, I get the following error message:
/cygdrive/c/Xilinx/10.1/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/4.1.1/../../../../microblaze-xilinx-elf/bin/ld.real: cannot open output file TestApp_Peripheral/executable.elf: Permission denied
collect2: ld returned 1 exit status
make: *** [TestApp_Peripheral/executable.elf] Error 1
Done!
The problem seems that cygwin or XPS changes the access rights to the file so I can no longer touch it. Not even from Windows or inside the Cygwin window can I read/write or change the access rights of this file.
I am really puzzled, I will stop calling the "clean project" but I have to find a way to clean up these files.
Really appreciate your help,
/Farhad
01-30-2009 07:28 AM
Ok,
I found the problem! I had a crashed debugger in the background that was blocking the access to that file. When I killed thar process, the file was removed :(
01-30-2009 07:28 AM
Ok,
08-03-2017 12:07 PM
