Problems when import peripheral in XPS
I have a custom ip which implement two bus interface: S00 defined as AXI4-Lite bus interface, S01 defined as AXI4 bus
interface. When i try to import it as a pcore in a XPS project using the create or import peripheral wizard,  it seems that
wizard will do some connection between signals(ports) which has a same suffix automatically.  I can specify all the
ports of S00 bus interface freely. But when i try to specify the ports of S01 bus interface, tools select the ports which has
the same suffix of S00 bus interface. What's more, i can NOT modify it even though i know it is wrong since there is no
other option to choose.
I am a little crazy about this!  Does someone can give me some suggestion to close the function of ports connection
automatically or some better choice to avoid this case. I am very appreciate!
Best Regrads,
Appley
Re: Problems when import peripheral in XPS
It seems that it is not a common issue, but i have no idea of this. Any suggestion would be greate appreciate!
Appley
