Problems while running hard ethernet mac test
I get following error while running TestApp_Peripheral on our custom board with Virtex 5.
Running TemacSgDmaIntrExample() for Hard_Ethernet_MAC...
LlDma: Error: IrqStatus & XLLDMA_IRQ_ALL_ERR_MASK
Does anyone have an idea where the problem is.
Test was passed with ML507 development board and xps_ll_temac part in mhs-file is exactly same in both of the designs.
Thanx,
pltl
I'm seeing similar symptoms trying to debug an SFP-based V5 design. I'm curious to know if you've tracked your problem, and if so, how.
Most likely, you had set a wrong clock ratio for the SDMA port in the MPMC. I had those same problems and it worked for me.
