www.moi.com
Problems with C/C++ project in SDK
Hi everybody,
i am beginner with Xilinx SDK.
I am actually trying to import an existing C project in SDK.
When building it, i have got these errors, with these lines in head:
../src/libjasper/ras/ras_dec.c:77:31: error: jasper/jas_stream.h: No such file or directory
../src/libjasper/ras/ras_dec.c:78:30: error: jasper/jas_image.h: No such file or directory
../src/libjasper/ras/ras_dec.c:79:30: error: jasper/jas_debug.h: No such file or directory
 This is a cpature of my screen:
I've tried to delete the pnm folder which contains the error, but, then, the same error appears in the upper folder (pgx in our case).
I don't know how to deal with this problem.
Thx for any helpful idea from you.
iguaner
I am not familiar with SDK 11.5 but in SDK 13.2 it looks like:
For 11.5 try to search around this setting or add the path to gcc command line manualy.
iguaner
try to directory with "H" files to your include path (in SDK right click on project -> C/C++ build settings -> Directories -> include paths)
www.moi.com
thx iguaner for the reply,
i've followed: >right clic on project>properties>C/C++ build> build settings>.. and then i can't find Directories or any thing about include paths.
Do you have any idea where can i find it ?
PS: I am using SDK 11.5.
iguaner
www.moi.com
yes!! that's it!!
thx iguaner
