Program FPGA failed issue in SDK
I have a question on SDK tool.
I got the message as below
I just connect jtag cable between the board & computer.
Then I tried to download
I got the message during download
Anyone know reason for this issue?
I have another question based on bit file
I want to know the detail of the relationship or difference between download.bit & xxx(project name).bit
such as the list below
download.bit
xxxxx.bit
xxxxx.elf
xxxxx.mmi
Anyone know the document number or tile for the definition or explanation of those file relationship?
Thank you
Community Manager
Community Manager
Re: Program FPGA failed issue in SDK
Can you delete these from your temp directory? It seems that SDK is unable to delete these files as its facing permission issues.
Also on your second query, download.bit intializes the bit file with the processor data from your elf file.
The file system.bit from your project , created after hardware generation , is an uninitialized bitstream and does not include the ELF file. It is only when you execute the command to download or update the bitstream that the system.bit and ELF files merge into download.bit.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pp_p_process_update_bitstream_processor_data_xps.htm
