Observer bozhu
Program Flash Memory is different between v2017.2 and v2017.4
SDK V2017.2:
It don't need to select the FSBL.
And it can flash the spiflash in JTAG , SD and QSPI  boot mode.
SDK V2017.4:
It need to select the FSBL.  (Question 1)
But it can only flash the spiflash in JTAG  boot mode. (Question 2)
And the FSBL must init the MIO8 to spiflash Feebback Clk mode. Otherwise ZYNQ will not boot from spiflash, but it can boot  if use SDK V2017.2.  (Question 3)
WHY ?!
Re: Program Flash Memory is different between v2017.2 and v2017.4
Hi @bozhu ,
Please check this AR, Hope it helps you.
https://www.xilinx.com/support/answers/70148.html
Thanks & Regards
Anil B
Thanks & Regards
Anil B
Hi @bozhu ,
Thanks & Regards
Anil B
Thanks & Regards
Anil B
Observer bozhu
Thanks!
