chaitusvk
Program not running with video test pattren generator
my hello world program is not running  with configuration as shownScreenshot from 2021-03-04 13-14-11.pngScreenshot from 2021-03-08 14-45-36.png
Timing error  were solved ..even then program not running ..
incresed stack and heap size ...to 8000 also
marcb
Hi @chaitusvk
The Forums community might be able to better help if more details can be provided on this issue. Is there a specific failure seen when launching on hardware? Is there more information about the sequence of events used?
Is the problem application specific or, does the issue fail on template apps like the peripheral test or hello world?
