mark@bish.net
Programming BBRAM (2017.3) error
I keep getting this error message in Vivado when attempting to program the bbr key.
Any ideas?  I've rebooted and restarted a bunch of times.
balkris
I am looking into this post meanwhile you can refer this discussion
https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2017-3-not-enabling-VU7P-ES1-devices/td-p/799664
Thanks and Regards
Balkrishan
mark@bish.net
I am using a node locked license for right now.
I am creating my bbram.nky key as follows:
In file generate_aeskey.bif-
generate_aeskey_image:
[aeskeyfile] bbram.nky
[bootloader, encryption=aes] zynq_mmp_fsbl.elf
then bootgen -image generate_aeskey.bif -o temp.mcs -encrypt bbram -p xc7z045
If I can provide any more detail please let me know.  Its put me at a standstill.
mark@bish.net
Also, my part is a xc7z045ffg900-1
It is found in 'get_parts' but bootgen fails if you specify the full part:
bootgen -image generate_aeskey.bif -o temp.mcs -encrypt bbram -p xc7z045ffg900-1
ERROR: syntax error
... bbram -p xc7z045ffg900-1
[ERROR] : Command line parsing failed with code 1
If you create it like this: bootgen -image generate_aeskey.bif -o temp.mcs -encrypt bbram -p xc7z045ffg900
Then Vivado complains:
balkris
Can you please try this commend
Can you refer this XAPP
XAPP1175 -  Secure Boot of Zynq-7000 All Programmable SoC Application Note( ver2.0, 7890 KB ) [PDF]
Describes how to boot the Zynq®-7000 AP SoC device securely using Quad-SPI and SD modes, including optimal use of RSA authentication and AES encryption.
Associated File(s)
Refer this wiki page to prepare boot image
http://www.wiki.xilinx.com/Prepare+boot+image
Thanks and Regards
Balkrishan
mark@bish.net
Here is the output of that command:
mark@stride:~/git_repo/ZMMP_7045_PetaLinux_PL2015_2/SDK_boot$ source /opt/Xilinx/Vivado/2017.3/settings64.sh
mark@stride:~/git_repo/ZMMP_7045_PetaLinux_PL2015_2/SDK_boot$ bootgen -image generate_aeskey.bif -o temp.mcs -encrypt bbram
[ERROR]  : Partname must be specified with -p <partname> option in command line for generating a key file
I've been going through that XAPP over and over.  My issue is loading the key into BBRAM for the boot from SD.
balkris
Xilinx BootGen
Build-2017.2, Date-May 18, 2017
Copyright (c) 1995-2017 Xilinx, Inc. All rights reserved.
COMMAND LINE OPTIONS |
-arch [options] | Xilinx Architecture |
| options: [zynq, zynqmp, fpga] |
-image <filename> | Input Boot Image File (.bif) |
-o <filename> | Output filename in MCS/BIN format |
-w [options] | Overwrite mode |
| options: [on, off] |
-encrypt [options] | AES Key storage in chip (Zynq only) |
| options: [bbram, efuse] |
-p <string> | Part name |
-efuseppkbits <filename> | Generate PPK hash for e-fuse |
-generate_hashes | Generate SHA hashes (PKCS#1v1.5) |
-spksignature <filename> | Generate SPK signature file |
-fill <hex-byte> | Fill byte for padding |
-split [options] | Split partitions to diff files |
| options: [bin, mcs] |
-padimageheader [options] | Pad header tables |
| options: [0, 1] |
-process_bitstream [options] | Outputs bitstream in bin/mcs format |
-generate_keys auth [options] | Generate Authentication Keys |
| options: [pem, rsa] |
-dual_qspi_mode [options] | Generate 2 output files for Dual QSPI |
| options: [parallel, stacked <size>] |
-log [options] | Generate log file |
| options: [error, warning, info, debug, trace]|
-zynqmpes1 | Generate boot image for (1.0)ES1 |
-h | -help | Print the help summary |
-bif_help | Print the BIF help summary |
Note : For more info on bootgen options, use the command |
bootgen -help <option> |
Example : bootgen -help efuseppkbits |
Thanks and Regards
Balkrishan
mark@bish.net
mark@stride:~/git_repo/ZMMP_7045_PetaLinux_PL2015_2/SDK_boot$ /opt/Xilinx/SDK/2017.2/bin/bootgen -image generate_aeskey.bif -o temp.mcs -encrypt bbram
Same error regardless if I use 2017.2 or 2017.3
Also, the MD5sum is the same for both bootgen
mark@bish.net
Are there any other channels to get more formal support from Xilinx for this issue?
sylvainsgndt
I get the same problem. Did you, by any chance, figured out a solution? I read the links the moderator sent you and it looks like he just not read your question or was just trying to send you to the "user manual" without even noticing that Xilinx Software merge your home directory with the part name, which sounds like a bug to me.
Thanks in advance
pmallad
I was successful in programming the BBRAM key using Vivado
This is the bif:
    [bootloader, encryption=aes] zynq_fsbl_0.elf
This is the command:
bootgen -image generate_aeskey_image.bif -o temp.mcs -encrypt bbram -p xc7z045
mark@bish.net
@sylvainsgndt  I had to move on.  I'm coming back to it but it is going to be a few months.
liwenz
I got the same error.  in 2015.4
I follow the xapp1175, with  bootgen -image generate_aeskey.bif -o temp.mcs -encrypt bbram
it tells me -p partname need.
I add -p xc7z010
it runs and report the program fall down
