fiedel
Python version for Petalinux.
Where can I find the Python version for each Peatlinux release? I didn't see it in ug1144. I strugled a lot when I started to use Petalinux, and I don't suffer from python version again as I plan to upgrade to 2019.2.
Or, 2019.2 still uses Python 2.7?
vineethc
The python package for petalinux tool comes from within.
Petalinux leveragtes build tools concept of yocto.
It is independent of host python version.
vineethc
fiedel
That makes me feel much better. Maybe I have corrupted memory...
vineethc
what was the error ?
erjo1776
~/tools/u96a$ bash petalinux-v2018.3-final-installer.run ~/tools/u96a
INFO: Checking installation environment requirements...
WARNING: This is not a supported OS
INFO: Checking free disk space
INFO: Checking installed tools
ERROR: You are missing the following system tools required by PetaLinux:
- python
Please check PetaLinux installation guide - required tools and libraries package section for detailed information
INFO: Checking installed development libraries
Please install them with your operating system package manager, and try again
WARNING: Please install required packages.
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
----------btw, I too am trying WSL Ubuntu under Windows 10 pro-------------
akarshana
I am getting same error please let me know the solution for this
