Observer nenghan
QEMU hostfwd does not work
I cant get to connect from the host to the qemu.
What i did:
- Using Petalinux 2018.2 and XSDK 2018.2
- Download ZCU102 2018.2 BSP
- petalinux-create -t project -s <BSP>
- petalinux-config -c rootfs -> just to check that the tcf-agent is enabled
- petalinux-build
- petalinux-boot --qemu --kernel --qemu-args "-netdev user,id=mynet0,hostfwd=tcp::1534-:1534,hostfwd=tcp::5555-:22"
qemu booted up well and when ifconfig shows:
root@xilinx-zcu102-2018_2:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0A:35:00:22:01
inet addr:10.0.2.15 Bcast:10.0.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:25 errors:0 dropped:0 overruns:0 frame:0
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:6465 (6.3 KiB) TX bytes:2916 (2.8 KiB)
Interrupt:31
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%4882584/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:24 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5892 (5.7 KiB) TX bytes:5892 (5.7 KiB)
I am able to ssh from qemu to host using following:
root@xilinx-zcu102-2018_2:~# ssh admin@10.0.2.2
Host '10.0.2.2' is not in the trusted hosts file.
(ecdsa-sha2-nistp256 fingerprint md5 da:78:2a:74:bc:54:01:f7:9c:6d:e7:25:14:22:43:89)
Do you want to continue connecting? (y/n) y
admin@10.0.2.2's password:
Last login: Fri Aug 24 21:47:36 2018 from localhost
[admin@localhost ~]$
However when i used xsdk and set the tcf-agent to test connection to 'localhost' at '1534', it cant connect. I checked that the tcf-agent was running using top in qemu and it was
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
2323 2316 root R 3336 0.0 0 0.2 top
2307 1 root S 30016 0.7 2 0.1 /usr/sbin/tcf-agent -d -L- -l0
1597 2 root SW 0 0.0 2 0.0 [kpktgend_2]
52 2 root IW 0 0.0 0 0.0 [kworker/0:1]
1598 2 root SW 0 0.0 3 0.0 [kpktgend_3]
1595 2 root SW 0 0.0 0 0.0 [kpktgend_0]
1596 2 root SW 0 0.0 1 0.0 [kpktgend_1]
2263 2 root IW 0 0.0 1 0.0 [kworker/1:2]
2314 2312 root S 3744 0.0 1 0.0 /bin/login --
1867 1 root S 3560 0.0 3 0.0 /sbin/udevd -d
2316 2314 root S 3388 0.0 0 0.0 -sh
2222 1 root S 3220 0.0 2 0.0 /usr/sbin/inetd
2296 1 root S 3092 0.0 2 0.0 /sbin/klogd -n
2293 1 root S 3092 0.0 3 0.0 /sbin/syslogd -n -O /var/log/messa
2315 2313 root S 3092 0.0 2 0.0 /sbin/getty -L 38400 tty1
2278 1 root S 3092 0.0 1 0.0 udhcpc -R -b -p /var/run/udhcpc.et
2313 1 root S 3012 0.0 3 0.0 {start_getty} /bin/sh /bin/start_g
2312 1 root S 3012 0.0 1 0.0 {start_getty} /bin/sh /bin/start_g
2285 1 root S 2432 0.0 1 0.0 /usr/sbin/dropbear -r /etc/dropbea
1 0 root S 1796 0.0 0 0.0 init
When i try to ssh from host to qemu using 'ssh localhost -p 5555', it timeout.
I believe the port forwarding from host to qemu is not working. Anyone have any ideas? I am using things direct from xilinx BSP and no modifications.
Re: QEMU hostfwd does not work
can you try with -redir. for example:
petalinux-boot --qemu --kernel --qemu-args="-redir tcp:1440:10.0.2.15:22"
Observer nenghan
Thanks it works. I remembered I tried this previously too but it didn't work for me then. The only thing was that I did a yum install of dhcp before trying again today.
