Visitor kpit
Qemu Error main-loop: WARNING: I/O thread spun for 1000 iterations
   I am facing the following error while running a standalone code on ZCU702 using QEMU.
Qemu throws this error when I start execution and then the code does not work.
Is there a possible solution for this?
Re: Qemu Error main-loop: WARNING: I/O thread spun for 1000 iterations
You can try force everything to be blocking. You have to set a variable in the main loop which controls blocking.
Thanks and Regards
Balkrishan
Go to QEMU source file "vl.c", and you must be seeing this below line in the file:
nonblocking = !kvm_enabled() && !xen_enabled() && last_io > 0;
Just comment it out and instead set this variable to 0, something like this:
nonblocking = 0;
Check this, it should probably work
Best Regards
Shabbir
Visitor kpit
I am using the executable that I got when I installed the XSDK. From where do I clone the source files?
Observer nenghan
I cant seems to find the vl.c file. Can you let us know the path? Thanks.
