R_MICROBLAZE_32_PCREL_LO
I am using XSDK from ISE 14.4 to compile a microblaze SW for Spartan-6.
Now i get this linker error:
./c5.base/diag/LinDiag.o: In function `LinDiag_AddListener':
(.text+0x988): relocation truncated to fit: R_MICROBLAZE_32_PCREL_LO against symbol `microblaze_disable_interrupts' defined in .text section in ../../standalone_bsp/microblaze_0/lib\libxil.a(microblaze_disable_interrupts.o)
collect2: ld returned 1 exit status
The first google hit is this Xilinx AR:
http://www.xilinx.com/support/answers/51605.html
But it is not helping, as I use version 14.4.
Is there a workaround?
Solved...
It turned out, GCC has this bug triggered by a weak function reference. The function used here was not mentioned.
It was from FreeRTOS, which uses:
extern void vApplicationExceptionRegisterDump( xPortRegisterDump *xRegisterDump ) __attribute__((weak));
After changing it to a normal function (non-weak), and having a single implementation, the linker error disappeared.
