RS232 problem in virtex 4 Ml403
Hello
 In my Virtex 4 ML403 I have used a rs 232  connector in which i f I use xil_printf or xuarlite_send byte functions then its workss good but in case xuartlite_recvbyte function it doesnot take any input from key board...is it prblem of my RS232 adapter
What adapter is best for virtex 4 and can I have the pin configuration of that?
regards
Anonymous
Not applicable
Re: RS232 problem in virtex 4 Ml403
see the attached doc, see if this helps?
thanx for the doc.it shall be highly helpful to me if somebody gives me the schematics of pin of rs232 cable which shall work with virtex4
