Random error in xstatus.h
I get an error in xstatus.h even if I cleaned the project
https://image.prntscr.com/image/4ciWWAr0RQOEw1bilagNGw.png
The source code folder has an X on it that shows there is an error in a file but no file has an X on it showing that there is an error..
Re: Random error in xstatus.h
The error was from returning those 2 values in a void function instead of just using return;.
@tester11 The error is not there. It is likely somewhere in your code. Look at the compiler logs.
