Visitor darkhero1221
Re: How to add a CoreGenerator into XPS project
Hi all!
I'm a new member, i have problem same topic,
i don't know method to add add a block ram into XPS project
Some body help me, can you show me some step add block ram ( in ISE) into project (XPS)
thanks all!
Please check if below links can give you a start
http://www.xilinx.com/support/documentation/application_notes/xapp967.pdf
http://forums.xilinx.com/t5/Embedded-Development-Tools/CoreGEN-memory-as-IP-in-XPS/td-p/68332
Refer this link. This has an example to import a netlist generated using CoreGen into XPS environment.
--Hem
