kiranhollag
Reading Zynq-7000 SoC's XUARTPS_FIFO_OFFSET using XSDB
In the case of Zynq-7000 SOCs, using XSDB, is it possible to read UART RX FIFO contents?
FIFO's absolute address is 0xE0001030 (considering Uart1) and read to this is resulting in following error in XSDB
"Memory read error at 0xE0001030. Blocked address 0xe0001030. Cannot access read-once register "
Kiran
stephenm
I have updated the script to allow print, and read for the UART:
proc print {addr string} {
foreach char [split $string ""] {
scan $char %c ascii
set data "0x[format %x $ascii]"
mwr -force $addr $data
#return the decimal value in the TX FIFO
proc get_data {addr} {
set data [mrd -force $addr]
set data [lindex [split $data " "] 3]
set data 0x[string range $data 6 7]
return [expr $data]
proc read {addr buffer} {
set buffer_data ""
while {1} {
set data [get_data $addr]
if {$data != "00000000"} {
lappend buffer_data $data
if {[llength $buffer_data] == $buffer} {
return [binary format c* $buffer_data]
connect -url TCP:XIRSTEPHENM32:3121
targets -set -filter {name =~ "APU"}
source ps7_init.tcl
ps7_init
#print 0xe0001030 "Hello Kiran"
#read 0xe0001030 11
If I run the read <addr> <buffer>
This will do a while until there is data to read, and return when the amount of characters specified in buffer is fulfilled
stephenm
You can use the -force switch.
For example, I created a simple demo that uses the XSCT to print to the UART1 on a ZC702:
scan $char %c ascii
source ps7_init.tcl
ps7_init
If I execute this, I see the data on the serial port:
stephenm
scan $char %c ascii
return [expr $data]
set buffer_data ""
while {1} {
source ps7_init.tcl
ps7_init
#read 0xe0001030 11
kiranhollag
Hi Stephen,
Thanks for the quick reply and the script...
it solved our issue :)
Kiran
