prsullivan
Redirect stdout to a FreeRTOS queue
I am trying to redirect stdout to a freertos queue. I have gathered that I will have to make a custom driver that supports the stdout interface using an .mdd file. it seems that drivers have to be associated with some sort of ip, so im not sure what to put for "supported peripherals" in the mdd file so that this custom driver will show up as an option in the stdout configuration options in the bsp settings.
Should a mld or mss file be used instead of an mdd?
