leo_skadoosh23
Refresh Expressions window
Hello everyone,
I am using the expressions window to see the present values of my variables. There is a refresh button at the top, that refreshes the values and displays the most recent ones.I am using SDK 2018.2 with Zynq 7020 board to operate a power converter. I noticed that clicking on the 'Refresh' button creates glitches in my system and at times even trips my converter. I am afraid that this Refresh button is some kind of an interrupt to the CPU, that's given more preference that my system interrupts. I have attached a snapshot of the window.
I would like to know if this is the case and how to avoid it. If not, I would like to know of another way to see my variables without using printf / xil_print functions.
Thank you.
Best regards,
Pramod
ibaie
Hi @leo_skadoosh23
I would say that the debugger is generating the glitch while accessing to the memory to read out the variables. I'm not sure if it is going to work for you but you could try to increase your JTAG frequency so the fetching of the data gets faster than normal speed.
Ibai
leo_skadoosh23
Hello @ibaie ,
It is a very inconsistent issue. I have tried increasing the JTAG frequency, but it still happens once in a while.
ibaie
Hi @leo_skadoosh23
I guess that the issue then might be just pure bottleneck issue accessing to those memory addresses while your system is running.
Ibai
