engrpetero
Rename a Vitis project
I searched the fora and didn't find much regarding renaming projects.  My specific desire is for a Vitis project.
I've didn't find anything in UG1400 - Vitis Unified Software Platform Documentation - Embedded Software Development.  Neither did I find anything while googling 'vitis rename'.
I tried exporting an existing project and them importing to see if I could change the name on import.  No luck.
Is there a method to change an existing Vitis project name?
@engrpetero
In Vivado, from the main screen menus you can do "File > Project > Save As..." to save the project using a new name.   Is this not available in Vitis?
Mark
engrpetero
There is a 'rename' option on the file menu.  However, it only seems to be available for a project file (.sprj).  I can't seem to rename the top level project  (the applicatoin project, for example) as the 'Rename' option is grayed-out on the top level project.  And if renaming the sprj file, next time the project is built Vitis just recreates a new sprj file with the top level project name.
