lymanhorne
Running SDK build standalone app over JTAG on Zynq SoC
I am trying to run a standalone app over JTAG on a Zynq 7030 and windows SDK. I can program the PL but when I try to launch the app for the PS, a window titled "Problem Occurred" pops up that says 'Launching <app name>' has encountered a problem. An internal error occurred during: "Launching sw-ferox". Under Details is says "An internal error occurred during: "Launching <app name>". java.lang.StackOverflowError".
Is there something I can do to overcome this java stack overflow?
In the DSK under Run->Run Configurations:
Xilinx C/C++ application (System Debugger)"
Under target setup:
Debug Type: Standalone
Connection: local
the bit file and init file are set and I have the following checked:
  Reset entire system
  Program FPGA
  Run ps7_init
  Run ps7_post_config
Application Tab:
I am pointing to the .elf file for ARM0
All the other tabs are set to defaults.
pvempati
Which SDK version you are using?
Please share the design.
Thanks & Regards,
Praveen Kumar. V
