Running hello_world as standalone application on Zynq in BOOT.BIN
I've created a BOOT.BIN file using the "Create Boot Image" tool in SDK with these files added in the following order:
zynq_fsbl_0.elf
system.bit
hello_world_0.elf
When I load it into either an SD card or SPI flash and power on I can tell the PL is configured as I have LEDs blinking from hardware, but my hello_world program won't run.
In "Create Zynq Boot Image" is there a trick to get the bootloader to jump to the standalone application?
I reverse the order of system.bit and hello_world_0.elf the PL doesn't load.
Re: Running hello_world as standalone application on Zynq in BOOT.BIN
I found that if I cycle the power on the board a few times it eventually works. Would like to know if anyone has any insight as to how to make the process more reliable.
Hey
I want create bootloader like BOOT.BON but I want load the bootloader on the flash of the Arm.
Best Regards.
I've just had the same problem. Make sure that your FSBL and application linker scripts don't point to the same location. E.g. set the FSBL to be in processor 0's RAM and the application to be in DDR. That worked for me.
